20 Most Recent BMW 3 Series 92-98 Questions & Answers
WHATS THE RADIO CODE FOR A 98 BMW 323IS???
Every BMW radio has a different radio code. It's an anti-theft device. If you are the original owner of the vehicle and still have the owner's manual package you should be able to find a card in the package labeled "Radiopass" that will have the code. If you don't have the pass there are a couple of ways to get the code depending on the model of the radio. If the radio is still in the car simply turn the radio on and press and hold the "m" button within a few seconds of turning the radio on to get the radio's serial number. That will be the number needed to get the radio code. Not all BMW radio models have that feature. If you cannot retrieve the serial number that way you will need to remove the radio and get the number from a sticker or plaque on the radio. At this point you will need to take that number to a dealership and have them get the radio code for you. NOTE: if you bring them just the number or just the radio and are not able to provide proof of ownership they will not give you the code. Be prepared to prove that you are the rightful owner with a copy of your registration and driver's license. BMW typically requires that both pieces of ID have the same name and address so you won't be able to send someone else on your behalf.
1/16/2011 3:25:34 AM • BMW 3 Series... • Answered on Jan 16, 2011
2answers
Lost code BMW Becker 7969 Ser. 65010730 Thanks
Dealership with the reggo document is the easiest way. https://www.google.com/search?q=bmw+becker+radio+code+calculator .
6/30/2022 5:08:29 PM • BMW Car Audio &... • Answered on Jun 30, 2022
2answers
I NEED A 1998 BMW 328IC RADIO COD S#
You will need to contact your local BMW Dealership to retrieve the Radio Code. This is free as long as you can prove you are the owner of the Vehicle. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
9/14/2021 8:25:43 AM • BMW Car Audio &... • Answered on Sep 14, 2021
Eonon d5150 screen problem
I Just bout an r32 mk5 golf 4motion and it has eonon unit. The touch screen not working I can not move up or down the icons to turn blue tooth on. Or anything cant select between USB stick and sd card and not showing any maps the touchscreen not in any operation at all. Has anyone had this issue
6/5/2019 10:31:38 AM • BMW Car Audio &... • Answered on Jun 05, 2019
Wiring accessories to bmw 218
what kind of accessories
3/5/2019 2:21:15 AM • BMW Car Audio &... • Answered on Mar 05, 2019
Hi .i have e53 2006 Radio and select Botton stop working Light on , but all left block from the screen not working Thanks
the lcd screen is bad your best bet is to replace with after market
3/5/2019 2:19:36 AM • BMW Car Audio &... • Answered on Mar 05, 2019
2answers
I have a Apline CHM-S601 6 disk changer in my 1999 BMW 528i. every cd I play skips extremely bad. Is there something I can do to correct the problem?
Try buying and using a laser lens cleaner disk to try and resolve this.
10/9/2018 9:38:05 PM • BMW Car Audio &... • Answered on Oct 09, 2018
Bmw business cd bluetooth
11/15/2017 9:54:40 PM • BMW Car Audio &... • Answered on Nov 15, 2017
How to reset cd changer on BMW 1999 323i
The only reset is to disconnect power to the changer at the fuse box for 30 seconds. I doubt that will help, you likely just have a defective player.
5/16/2017 10:53:15 PM • BMW Car Audio &... • Answered on May 16, 2017
2answers
97 BMW 528i cuts off when I step on the gas
Check your fuel pressure at idle and when at higher rpm while not driving. You can usually borrow a pressure tester from an auto supply store. The place to test it will be on the fuel injection rail on top of the intake manifold. I would buy a Haines manual too.
7/9/2016 2:05:45 AM • BMW Car Audio &... • Answered on Jul 09, 2016
Stereo won't work cause I need the code I don't
you may have to get in touch with a car dealer to see how much they charge to reset your computer to accept the aftermarket radio
7/18/2014 6:11:39 AM • BMW Car Audio &... • Answered on Jul 18, 2014
0answers
Eonon car
Be the first to answer 4/14/2014 4:40:50 AM • BMW Car Audio &... • Posted on Apr 14, 2014Be the first to answer
Secuity codes for a BMW radio
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your BMW service centre and get them to enter this code for you.
12/10/2012 8:52:40 AM • BMW Car Audio &... • Answered on Dec 10, 2012
I found water in around amp in battery compartment
you may have to take the amp apart and clean any corrosion off inside of the amp. if the corrosion ate any of the leads of components or any traces, you may have to replace the amp. this is assuming it is the factory amp you are talking about.
3/25/2011 4:48:38 PM • BMW Car Audio &... • Answered on Mar 25, 2011
Need code eurovox 7479b serial n 294000871.5.
The cheapest and best I can suggest are these, Cheaper than Dealer by a long way and guaranteed. You will need make, model and serial number.
Hope it helps.
http://uk.ebid.net/for-sale/car-radio-unlock-codes-39361901.htm
3/20/2011 10:03:39 PM • BMW Car Audio &... • Answered on Mar 20, 2011
Bmw
Be more specific with your details.
3/9/2011 8:12:38 PM • BMW Car Audio &... • Answered on Mar 09, 2011
I have a problem with my 2000 bmw 528i. I
very interresting. could be that one of the cables short to ground due to damaged insulation. there is no logic that a fuse is blown without shortage or over currency. i dont think it will cause any problem to remove hole unnecessary cables.
please feel free to contact me here under your topic if any further assistance is needed
regards
2/28/2011 11:39:00 PM • BMW Car Audio &... • Answered on Feb 28, 2011
BMW 3 Series 92-98 Logo
2 questions posted
Top BMW Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • BMW Car Audio & Video
Most Popular Question
whats radio code 98 bmw 323is
  • Car Audio & Video
