FixYa.com
NEC PlasmaSync 42MP1 42 in. Television
All Products > NEC > Flat Panel Televisions
Problems with NEC PlasmaSync 42MP1 42 in. Television?
Troubleshooting and Support
Solved Problems for NEC PlasmaSync 42MP1 42 in. Television RSS Feed Post a New Problem
Does anyone have ANY info on these?  The unit originally came in with the following problem: Turn it on and...
2 Solutions
NEC 42mpi plasma tv not working
42 Inch NEC Plasma Sync 42 MPI TV doesn't power on
1 Solution
Black Screen
The resolution was changed on the monitor now it has a black screen.
1 Solution
NEC 42MP1 Broke - Help!
Hi all, I  have an NEC 42MP1 plasma which doesn't fire-up.  When it's switched-on, the green power...
24 Solutions
just read about these new DVD player that...
just read about these new DVD player that "upconvert" to HD. They require a TV with a DVI or HDMI input. I...
1 Solution
How do I know if a plasma TV will show...
How do I know if a plasma TV will show high-definition (HD) signals?
1 Solution
lcd tv
Hello. I have Gateway flat TV: GTW- L17M103, also I have audio but I have no video. Any ideas? Thanks.
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC PlasmaSync 42MP1 42 in. Television RSS Feed Post a New Problem
Problem with NEC PlasmaSync 42MP1 42 inch...
Hi. My NEC 42MP1 plasma will power on, but I hear a high-pitched whine, hear a couple relays switch off/on and then goes...
Post a Solution
My TV keeps switching to standby for no...
My NEC 42" Plasma screen turns off and goes onto standby. The green light sometimes shows for about 2 seconds...
Post a Solution
Plasmasync 42 (2004)
My TV has been great, a few days ago it started with strange screen abnormalities, in the upper middle, there seems to...
Post a Solution
My LCD Lg 32lc56 keeps going on Stand By
Please help. My LCD keeps going on stand by. When switched on again, it goes on Stand By again. When given a rest, and...
Post a Solution
service manual
all i want to know were can i get a service manual for this 42mp1 im a tech but im having problem with this tv i check...
Post a Solution
power button blinks, the screen does...
I would like to know if it's the power supply that is failing & if this is going to be an expensive repair?
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size42 inch
Flat Panel TypePlasma
Display Resolution853 x 480 pixels
Display Capabilities
Aspect Ratio16:9
Display Format1035i · 525i · 525p · 625i · 1080i (HDTV) · 720p (HDTV) · 480i (SDTV) · 625p
Image Quality
Contrast Ratio450:1
Pixel Pitch1.08 mm
Output Color16.77 million colors
Viewing Angle160
Audio Features
Audio TypeStereo
Technical Features
Sleep TimerWith Sleep Timer
Dimensions
Depth3.5 in.
Height25.5 in.
Width41.3 in.
Weight70.6 lb.
Warranty
Overall Warranty1 Year
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
