NEC LCD3000 30 in. HDTV Television
Problems with NEC LCD3000 30 in. HDTV Television?
Troubleshooting and Support
Solved Problems for NEC LCD3000 30 in. HDTV Television RSS Feed Post a New Problem
Maxent MX-42HPT51- will not respond!
Hello - We have had this set now for about 5 weeks. And after about 2-3 hours of watching the controls on the TV and...
Post a Solution
LG 42LB5DF turns on by itself and the...
I bought this tv second hand and all has been well but I got home the other day and the tv was on. I started watching...
1 Solution
My JVC PIP Won't work, pls help!
Hi, I just bought a JVC Flat Screen AV-21ST27. I hooked up all the cables properly: Cable Tv, DVD, VCR are all working...
Post a Solution
V-chip block on Jensen JE2269 Digital...
.We have the above described TV installed in our motor home. We plug in to cable at RV Parks or use Dish satelite when...
1 Solution
Parts
I own a digimate DG4200 42 in. Plasma , had a power surge picture went bad Can't find replacement part422BLOWR...
1 Solution
Remote suddenly desn't work
Vivatek 37" TV suddenly wont take commands from my remote...the remote that came with it. I tried to program a...
1 Solution
my tv
i have a citizen 24" and i accidentaly pull the cable socket fom back of tv so i wanted to hook up through dvd...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size30 inch
Digital TV StandardHDTV
Flat Panel TypeLCD
Display Resolution1600 x 1200 pixels
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Built-in TunerNTSC · PAL
Display Format1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote ControlStandard
Image Quality
Contrast Ratio350:1
Pixel Pitch0.5 mm
Brightness450 cd/m²
Output Color16.7 million colors
Viewing Angle170
Audio Features
Audio TypeStereo
Technical Features
Picture in PictureWith PIP
Sleep TimerWith Sleep Timer
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsComposite x 1 · S-Video x 1 · Component x 1 · DVI x 1 · 1 x D-Sub (RGB PC) · 1 x RS-232C · Audio (RCA) x 3
Rear Output ConnectorsComposite x 1 · Audio (RCA) x 1 · Component x 1
Screen Text
OSD LanguagesEnglish · French · Spanish · German · Italian
Speakers
Speaker Power7 Watt
Dimensions
Depth4.5 in.
Height17.7 in.
Width27.8 in.
Weight32.6 lb.
Warranty
Overall Warranty1 Year
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Experts
Ask Me
snakehead Wiz
11 solutions
Ask Me
Coldcut Wiz
16 solutions
Ask Me
robotek Guru
1 solutions
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
