20 Most Recent RCA Lyra RD2217 MP3 Player Questions & Answers
You need to convert First with any converter.
1) Make sure the HOLD/LOCK switch on the side is not turned on.
2) Make sure the files got riped into mp3 file format (right click on the rip file --> Properties, to see the information about the file).
3) Make sure you drag and drop (or copy-paste) the mp3 files into the MUSIC directory.
RCA Lyra RD2217... | Answered on Mar 04, 2014
First, install the software if any that came with your mp3 player and connect your mp3 player. If you want to add music to your mp3 player you can sync with your media player or copy and paste songs from my music folder to your mp3 player that's under my computer. To delete songs or files just go to my computer, click on your device and you will see your files, just click on any ones and press delete on your keyboard. To download music for your mp3 player, you will have to pay for songs at most places like itunes. There is one site that is called LimeWire, just go to www.limewire.com, download and install the software. Let me WARN YOU, that limewire is ILLEGAL and there is stiff penalties if you get caught.
hope this helps you out a little.
RCA Lyra RD2217... | Answered on Mar 16, 2012
I figured out how to fix it. You must first go to "my computer" with mp3 attached by usb. Once the main "my computer" box is open right click on whichever drive the player displays as. A list should appear with the selection to format. Once the format box opens after clicking format you have to change the FAT32 to FAT. Then click format and after that the player should work again. NOTE: The player takes awhile to boot up the format so give it 10 seconds at least. Hope this works for you!!
RCA Lyra RD2217... | Answered on Feb 27, 2009
Rca mp3 players **** i wasted like 70 dollars on a peice of **** that cant even start up
RCA Lyra RD2217... | Answered on Sep 08, 2008
i am not sure if you have this store there but i live in halifax and the store called the running room usually carries stuff like that
RCA Lyra RD2217... | Answered on Aug 31, 2008
Try the reset button on the back of the unit. This requires a pin or pencil point to activate. Note that this player must be disconnected from your computer by following the disconnect instructions in the owner's manual only, you cannot just unplug it.
RCA Lyra RD2217... | Answered on May 15, 2008
What make and model of MP3 Player do you have?
most MP3 players show up in "My Computer" as removable storage.
Just browse to the device and you will be able to view and remove your songs.
RCA Lyra RD2217... | Answered on Mar 24, 2008
I think the problem is that you deleted one of the syst. file on the RCA Lyra.. These are the files you need to have in order to make the mp3 player work.
Setting.dat
Music.sec
Time.dat
music.lib
and the 4 folders (Voice) (line-in) (FM) (audible)
RCA Lyra RD2217... | Answered on Nov 28, 2007
It sounds like your Friend,Try to load something to your Player,Take the model 3 and make and Put it in the Browser and look for the Proper Software For it you might lose the music you have on it,But at least,It will Work
RCA Lyra RD2217... | Answered on Jul 20, 2007
Hey dude... what program are you using to sync your music? because some programs are really dangerous you know and that may cause freezing.
RCA Lyra RD2217... | Answered on May 24, 2007
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_0.jpg For more details, check: How to Download Music from YouTube to iPod
RCA Audio... | Answered 38 minutes ago
This could be anything but I would guess you probably have a short in the system.If you could give me more information I may be able to help you better.
hardrocko
RCA Audio... | Answered on Sep 11, 2019
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
RCA Audio... | Answered on Sep 06, 2019
Hello Kathie, indicate model of the equipment that you are commenting, to be able to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Kathie, indica modelo de los equipos que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
RCA Audio... | Answered on Sep 05, 2019
Popular Tags
17 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
rca lyra mp 3 mc2601a bar code
  • Audio Players & Recorders
