RCA Scenium PHD50300 50 in. Plasma Television
Problems with RCA Scenium PHD50300 50 in. Plasma Television?
Troubleshooting and Support
Solved Problems for RCA Scenium PHD50300 50 in. Plasma Television RSS Feed Post a New Problem
RCA PHD50300 no picture on top half of...
My RCA 50" plasma PHD50300 recently started acting up, the top half of the screen would go black and after a power...
1 Solution
RCA Plasma Problem
Did you find out what was causing your plasma problem (top half of picture black)?
1 Solution
vertical line on screen
There is a vertical black line in the lower lefthand part of the screen that extends about halfway the length of the...
1 Solution
poor picture with hdtv Hitachi 37HDL52...
the tv works fine on video inputs(yellow) , but not properly using the component inputs from the cable box or the dvd...
1 Solution
V-chip block on Jensen JE2269 Digital...
.We have the above described TV installed in our motor home. We plug in to cable at RV Parks or use Dish satelite when...
1 Solution
Parts
I own a digimate DG4200 42 in. Plasma , had a power surge picture went bad Can't find replacement part422BLOWR...
1 Solution
my tv
i have a citizen 24" and i accidentaly pull the cable socket fom back of tv so i wanted to hook up through dvd...
1 Solution
Unsolved Support Problems
Unsolved Problems for RCA Scenium PHD50300 50 in. Plasma Television RSS Feed Post a New Problem
bad pixel
had 1bad pixel now there are 2 ,problem now lower half of screen works with really bad shadowing top half of screen is...
Post a Solution
rca scenium phd50300
plasma will not turn on it goes from gren back to red
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size50 inch
Flat Panel TypePlasma
Display Resolution1365 x 768 pixels
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Display Format1080i (HDTV) · 720p (HDTV)
Remote Control
Remote ControlUniversal
Image Quality
Contrast Ratio500:1
Comb Filter3DYC / 3D Digital
Viewing Angle160
Technical Features
Picture in PictureWith PIP
Sleep TimerWith Sleep Timer
Dimensions
Depth4.2 in.
Height30.2 in.
Width48.8 in.
Weight101.3 lb.
Warranty
Overall Warranty1 Year
RCA Contact Information
Main support number580-634-0151
Sponsored Links
Loading problems.
Top Experts
Ask Me
Drummerni Wiz
1 solutions
Ask Me
lukster Wiz
14 solutions
Ask Me
tvtek Wiz
10 solutions
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
