20 Most Recent RCA P60920BL 60" Rear Projection Television Questions & Answers
Just visit this link It has details about convergence procedure to rear projection television. Convergence adjustment procedure to most brands PTVs will be similar. Pull up older posts there, by its left side bar. http://electronicshelponline.blogspot.com/
RCA P60920BL 60"... | Answered on May 30, 2013
this will be need a trouble shooting, if you want a do it with your own check this part. first thing you need to do is removed the back cover of the tv so you can access the internal part. now at this time look for the power supply board this is where the power cord connected. check for a bulging capacitor pull out and replaced it with new capacitor. you can find replacement part at www.digikey.com.
RCA P60920BL 60"... | Answered on Nov 16, 2012
Look to see if for a tiny fraction of second the power light tries to come on----also from memory I do not know every set---is there a label on the rear with a "chassis" number like PTK169 etc?
RCA P60920BL 60"... | Answered on Jun 08, 2012
The beeping is usually caused by the Flyback transformer and HOT transistor. You can get the 239111 flyback and HOT repair kit from www.tvrepairworld.com
RCA P60920BL 60"... | Answered on Nov 23, 2011
REplace the single convergence IC its a STK730-130 you can get the replacement from www.tvrepairworld.com under the integrated circuit category.
RCA P60920BL 60"... | Answered on Sep 21, 2011
Sounds like the STK730-130 IC needs replacement. You only need one for your model. Its available from www.tvrepairworld.com its listed under the Integrated Circuits category.
RCA P60920BL 60"... | Answered on Aug 28, 2011
large problem in these sets... cause HVT or high voltage transformer.also horizontal output transistor. Avail from MCM electronics.
Please leave feedback
RCA P60920BL 60"... | Answered on Feb 18, 2011
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
RCA P60920BL 60"... | Answered on Aug 13, 2010
Replace the single STK730-130 IC on the convergence power supply board.
RCA P60920BL 60"... | Answered on Aug 04, 2010
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
RCA P60920BL 60"... | Answered on May 30, 2010
If you haven't used the autoconvegence option in the menu screen try that. If not clean the projection lenses inside the TV with qtips and alchohol with the tv on so you can see if the lenses are clean.
RCA P60920BL 60"... | Answered on Mar 10, 2010
This is usually the flyback transformer (IHVT-integrated high voltage transformer) and the HOT( horizontal output transistor) The transistor will read shorted, with a multimeter, if it is bad. It is mounted to a heatsink straight back from the flyback. It may have a metal clip that holds it tight to the heatsink.
It is a pretty easy fix if you can solder.
While you have the board out, check for any discolored resistors or blown capacitors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
RCA P60920BL 60"... | Answered on Mar 02, 2010
While you have the board out, check for any discolored resistors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
Go to the menu and select convergence (the tv menu). Move the bars until the lines are lined up perfectly. Repeat for each color, then exit the menu.
This varies for different tv's.
Contact me for more info
Thanks for asking!
-Josh
RCA P60920BL 60"... | Answered on Feb 26, 2010
INFORMATION I HAVE FOR THIS MODEL says it first made in late 1998--
I have a few questions:
Is the power light green?
Did you hear any frying sound or smell anything burning?
The more you tell me the better I can help you.
SD TECH
RCA P60920BL 60"... | Answered on Feb 21, 2010
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
RCA P60920BL 60"... | Answered on Jan 27, 2010
Hi
Thanks for using FixYa. To reset the picture you’ll need to reset all the Video menu options to their original factory setting for which you’ll need to follow this step-by-step procedure---
Press the Menu button and then use up or down arrow button to select the Video menu. Now press the right arrow button and then use up or down arrow button to select Video Reset then press the right arrow button to reset the Video menu options to original values.
If still the problem persists, then you’ll need to check for local interference such as an electrical appliance or power tool and also check the antenna. If required change the direction of the antenna.
To resolve the issue of double Screen, first check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. So we are doing real small adjustments. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run about 300-500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
RCA P60920BL 60"... | Answered on Dec 25, 2009
Theres a Small Board up over your Chassis will have STK730-010 black IC on it, Its your regulator IC replace it Call Mats Electronics 1-800-628-1118 Use STK730-020 $6.50 Tell them to send you a Catalog
RCA P60920BL 60"... | Answered on Dec 18, 2009
This is a chassis PTK195 and acommon fault with these sets, that causes the symptom you describe, is the flyback transformer goes bad.
If you're at all familiar with electronic repair you could start checking there (and horizontal output transistor shorts). If not have an RCA approved warrany repairer give you an estimate/service call.
Note: the good thing about these sets is the chassis is very common and easily removed for service (without bringing in the whole set.) .
Usual cost to repair flyback/ dead set symptoms $200-$350.
RCA P60920BL 60"... | Answered on Nov 24, 2009
Televison & Video Logo
Popular Tags
49 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
no picture constant beeping
  • Televison & Video
