20 Most Recent RCA P52921 52" Rear Projection Television Questions & Answers
A universal programmed for almost any of the older rca or ge codes will work; A universal RCA should not require any programming.
RCA P52921 52"... | Answered on Mar 18, 2012
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
RCA P52921 52"... | Answered on Mar 09, 2012
dale_earn387,
RCA always has the part number stamped on the board. It will be a six digit number and usually is preceeded by "P/N". I have worked on these units and would guess that many of the boards are the same. Check the part numbers and if they are the same and the physical layout of the board looks the same the boards should be interchangable. I could not determine through research if the parts are the same because the units are older. I did determine that the CRTs are identical which would mean that more than likely the control signal board for them will also work.
Thanks for using FixYa and for the great rating.
hardrocko
RCA P52921 52"... | Answered on Apr 19, 2011
Bad FBT flyback Transfomer Call Mats 1-800-628-1118
Also CK hori output Transistor.
RCA P52921 52"... | Answered on Sep 29, 2010
you need a repair. Contact the manufacturer for and authorized servicer.
RCA P52921 52"... | Answered on Jul 31, 2010
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resistors,must be change to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
RCA P52921 52"... | Answered on Jul 21, 2010
your convergence regulator is out .do you know about electronics?
i can help you on www.itvrepair.com
RCA P52921 52"... | Answered on May 19, 2010
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
RCA P52921 52"... | Answered on Apr 02, 2010
Probably a bad solder joint.
RCA P52921 52"... | Answered on Mar 10, 2010
hi,
it could also be caused by these
http://cgi.ebay.com/Original-RCA-FL231-Convergence-Fuse-259213-------ITC222_W0QQitemZ140374724954QQcmdZViewItemQQimsxZ20100116?IMSfp=TL100116231008r24715
you may need also to check these out
Note: It is connected on pin 11 of flyback, if it the microfuse is open
( meaning no resistance ) you may need to replace them, see the
image above .
it can also be caused by these diode
available @
http://servicemanuals.vstore.ca/product_info.php/pName/dl231-diode
include the capacitor too, CL230 ( 100 uF / 50 V )
if you need the full kit , here is the link
http://servicemanuals.vstore.ca/product_info.php/pName/rca-itc222-convergence-option-missing-repair-kit
these are the location of the FL231
you may need to clean the board with an air compressor or just
an ordinary paint brush to see the fuse.
Thank you for choosing FixYa for assistance. I hope that my
information proves useful to you. If so, please take a moment
to provide me with a positive rating. I'd really appreciate it.
Regards,
palaboy
RCA P52921 52"... | Answered on Feb 05, 2010
This can be due to bad solder connections, old/bad capacitors, defective convergence amplifiers, or other bad component. If you are not comfortable with electronics soldering and high voltage, I recommend a service shop. 350 to 450 bucks average repair. This is not a do it yourself for the average person.
RCA P52921 52"... | Answered on Jan 08, 2010
the convergence is out usually on the crts like this you have to replace 2 convergence ICs usually numbered STK392-110 or -120 or -150 or -180 or somthing similar. Sometimes the resistors in the same circuit are also blown and need to be replaced. I don't know what these are labeled on this tv. It is a pretty simple fix for someone who can use a soldering iron. After replacing the chips a full manual covergence is needed.
RCA P52921 52"... | Answered on Jul 03, 2009
hi,you need to replace the front control panel, 1 or more of the tact switches have failed, if your proficient at solder work you can replace the switches, if not replace the small board behind the front buttons, available from any local tv shop just bring them the complete model # of your tv, gl, video-tek
RCA P52921 52"... | Answered on Jun 04, 2009
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
RCA P52921 52"... | Answered on Jun 02, 2009
sounds like possibly the high voltage amplifier' just a guesas
RCA P52921 52"... | Answered on May 08, 2009
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
RCA P52921 52" Rear Projection Television Logo
46 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
screen colors not stay inline
  • Televison & Video
