my screen is blue picture comes in and out words fade , i have tried the color contrast i can make...
(More)
my screen is blue picture comes in and out words fade , i have tried the color contrast i can make the words clear , but the picture still fades, if i click up down channels it will come in clear for a few seconds
my rca p52960 projector wont turn on via remote and power button.. Fuse is still good.. Is there a...
(More)
my rca p52960 projector wont turn on via remote and power button.. Fuse is still good.. Is there a fix, if so how much approx?
rca bigscreen tv i cleaned the inside of dust and now picture is real grainy and a little out of...
(More)
rca bigscreen tv i cleaned the inside of dust and now picture is real grainy and a little out of focus. i think i may have tweaked the red green and blue projectors. how do i adjust them? i set them to middle position with wing nuts on the back but it still looks like an old 70's set with rabbit ears! is there a generic procedure for this? please help
TV is only four years old and keeps shutting off automatically by itself. Makes a popping noise when...
(More)
TV is only four years old and keeps shutting off automatically by itself. Makes a popping noise when shuts off. Sometimes will automatically come back on and sometimes will not for several minutes. Does this mean it needs cleaning on the inside?
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
