FixYa.com
NCR RealScan 7872  Fixed Mount
All Products > NCR > Barcode Scanners
Problems with NCR RealScan 7872 Fixed Mount?
Search inside NCR RealScan 7872 Fixed Mount Knowledgebase
Troubleshooting and Support
Solved Problems for NCR RealScan 7872  Fixed Mount RSS Feed Post a New Problem
NEED ACTIVATE READ OF CODE 128 IN NCR 7872...
HELLO, I NEED HELP TO ACTIVATE THE READ OF CODE 128 CODE BAR IN ONE NCR 7872 SCANNER. THANKS FOR YOUR...
1 Solution
Problems with BHT scanner
when downloading data to BHT (new lookup) it starts to transfer some information and then stops, and 'File transfer,...
1 Solution
lexmark printer drivers
i want to download lexmark X1100 series printer drivers no sirve
1 Solution
Optical Drive not working.
Hi! I use a Toshiba Tecra M5 notebook & it has MATSHITA DV RAM optical drive. This device is not working & the...
1 Solution
distributors requiring isbns when my CDs...
I have been seeking a distributor for my music products, initially three CDs. Because the CDs only have bar codes, is...
1 Solution
BARCODE Generator
Plz. tell me how to code alphabets and numbers in barcode
1 Solution
change region code on my apple mac
I have bought a DVD from Amazon and can't play it because I can't change the regio code on my computer - how do you do...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeFixed Mount
InterfaceRS-232
ConnectivityWired
Optical
Light Sourcevisible laser diode (VLD)
Scan Rate6400 Scans per second
Technical Features
Special FeaturesUpgradable Flash Memory
Decode CapabilityCode 39, Code 128, Interleaved 2 of 5, UPC/EAN, RSS, Code 3 of 9
Environment protectionHumidity: 5% - 95% non condensing
Dimensions
Depth20 in.
Height3.5 in.
Width14.32 in.
Weight14.32 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
