20 Most Recent RCA P61929 TV Questions & Answers
Hello, the problem you are seeing is most likely caused by bad (leaky) push button switches. This is a very common problem in RCA, GE, and many other brands.
With the power unplugged, try pressing all the switches several (many) times. If the problem changes, or seems corrected for a time, then the switches are certainly bad. The problem may be corrected for a time, but it will likely return. Also, please be aware that since these switches commonly fail, the other switches may start acting up, too.
If you wish to replace the switches yourself, they are very inexpensive and can be found at www.mcmelectronics.com.
Replacing these switches is not that difficult, but soldering equipment and good soldering skills are required. If you wish to have a local shop do the repair, it should cost about $100-125 (in my area) if the TV was taken in to the shop.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
RCA P61929 TV | Answered on Jun 23, 2011
try to resolder all bad cold solder and open ones
see if this helps good luck
RCA P61929 TV | Answered on May 06, 2009
this my good sir, (or mam), is a convergence issue. very common rca failure. there is a convergence power module that has a 130volt regulator that goes bad. this can be fixed in-home by experienced technician for less tan 300.00 including parts, labor .& service call. the chip is an stk730-150. mch
RCA P61929 TV | Answered on Mar 09, 2009
just unplug the unit from main power outlet for sometime then replug it and check out .this mostly gets resetted.
RCA P61929 TV | Answered on Dec 04, 2008
The only remotes that turns everything off are satellite remotes.
(Dish Network, Direct TV, Shaw, and Bell)
RCA Televison &... | Answered 21 hours ago
The one they sent is an older model by 1.
Having said that it is a very minor change so the question is "does this tv have all the functions of the F model and is the picture ok??
RCA Televison &... | Answered 22 hours ago
You could use your untill you can find a remote to use ...its easy just check on playstore
RCA Televison &... | Answered 2 days ago
Hello, if there are digital audio adapters, optical or coax audio to the RCA, with this adapter, you can exit the TV from the digital output (it can be fiber optic or coax) n you enter the adapter and connect a cable with pair of RCA and the other end of this cable, two RCA also, to the input of your sound equipment
I sent you the link of an adapter
I do not suggest using the headphone output
I hope you can solve your need
Greetings Franco Dosil
Hola, si hay adaptadores de audio digital, ?ptico o coaxial a audio para los RCA, con este adaptador, sales del televisor desde la salida digital (puede ser por fibra ?ptica o por coaxial) y entras en el adaptador y conectas un cable con par de RCA y la otra punta de este cable, dos RCA tambi?n, a la entrada de tu equipo de sonido
Te env?o el link de un adaptador
No te sugiero usar la salida de auriculares
Espero puedas resolver tu necesidad
Saludos Franco Dosil
https://www.amazon.com/Optical-Digital-Converter-Support-Control/dp/B07BKX8BV7
RCA Televison &... | Answered on May 15, 2019
The remote codes are based on the unit the remote is controlling, not the remote itself.
The full list of Remote codes is here
https://www.remotecodelist.com/remotes/rca/rca.htm
RCA Televison &... | Answered on May 10, 2019
Televison & Video Logo
11 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
rca 61
  • Televison & Video
