20 Most Recent RCA F36685 36" TV Questions & Answers
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
RCA F36685 36"... | Answered on Dec 05, 2017
The main board to your TV has the fault. Check and replace it. The work is a skilled one, and not a user reparable. Contact any experienced service technician.
RCA F36685 36"... | Answered on Jan 09, 2013
how to reset my HD52w59..
RCA F36685 36"... | Answered on Jan 08, 2013
Clcik here to get an idea about flyback transofrmers.
RCA F36685 36"... | Answered on May 17, 2012
Hi, in most of these RCA TV, we found a common problem with that strange sound.
You need electronics skills to solve this problem. The sound coming from the TV ( back cover), caused by a faulty transformer T14401 location number, part number 241319, also a transistor horizontal output is shorted need be replaced. location Q14401 part number, part number 237470. This is a difficult and you may have to find a tv shop and ask for a previous estimate of money. I hope all this clear in my explanation and if you have further questions, I'll be here to help.
RCA F36685 36"... | Answered on Aug 18, 2011
try fine tuning channel 3
RCA F36685 36"... | Answered on Sep 09, 2010
You are describing normal operation. I have a Samsung with the 4:3 screen aspect ratio and deal with the same issues. With a program that is broadcast as HD I have the "letter box" pic. since this is needed to amintain the 16:9 ratio it is formatted in. Some programs come up as only filling part of the screen & at times I find the zoom mode less objectional to view. Even if you have a wide screen set you still deal with programs that are not in the 16:9 format. Perhaps eventually all programming will be in a consistent format, but for now we just have to put up with it. The good news is that your TV is not defective.
RCA F36685 36"... | Answered on Nov 19, 2009
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If not a part the unit will need a firmware upgrade. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher. A firmware upgrade shouldn't be more than $200 unless the manufacturer charges a lot for the software.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
RCA F36685 36"... | Answered on Jul 11, 2009
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
RCA F36685 36"... | Answered on Jun 18, 2009
check the scart cable/adaptor
RCA F36685 36"... | Answered on May 18, 2009
Probable bad flyback transformer....verify service number
last three digits YX2....Part # is 244247.............................T.
RCA F36685 36"... | Answered on Apr 29, 2009
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
RCA F36685 36"... | Answered on Mar 30, 2009
ahhh the noise maker comes to life again .. Ok my friend this is a common problem with this set If your lucky?? If you know anything about trouble shooting tvs then this is what ya got.. Try first to measure the Horizontal output transistor. It will meaqsure a few ohms between the base and emmitter. But the base and collector should measure about 450 to 550 olms on the diode settings onm the metter.if it measures shorted you need to replace the flyback tranformer along with the Horz output transistor. Now if the HOT( thats horiz output transistor)is not shorted then theres a little coil in the horizontal drive thats causing problems as you need to take out the coil from the PCB and scrape off the ends and reinstalkl it. also the horizontal driver tranformer as well as the resistor that feeds the transformer could be bad and thast is a 3200 ohm at three watts. if ya dont have a clue what I just said the sets gonna cost ya ariynd 200 to 300 to fix .. Is it worth it to ya>?????lol Good luck
RCA F36685 36"... | Answered on Jun 08, 2008
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
RCA F36685 36"... | Answered on Feb 28, 2008
YX2 = part # 244247..................................................T.
RCA F36685 36"... | Answered on Feb 01, 2008
Part # 207768 .......................................................T.
RCA F36685 36"... | Answered on Jan 15, 2008
RCA F36685 36" TV Logo
Popular Tags
25 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
thermistor
  • Televison & Video
