20 Most Recent RCA F36673ET 36" TV Questions & Answers
This tv is a CRT-(Tv tube)?Sorry this is a analog tv finding the analog tv parts now are nearly or almost impossible.
RCA F36673ET 36"... | Answered on Dec 06, 2018
Hello
You just check whether the remote control has infrared light emission from it or not. It can't be see with our eye, as infrared rays are invisible to us. Put new cells in the remote handset before you proceed. If you have a cellphone with camera option, the things are easy. Put the cellphone on camera mode, and place your remote control just in front of its lens, at about one feet away or so, press each button on your remote handset, The camera will sense the infrared radiation, and you can see its image on its screen. If there is infrared radiation sign, and still your TV doesn't respond to it, your TVs infrared sensor inside it is faulty. It comes just behind the infrared window ath the front panel of your Tv. It is a three terminal component, and can be resoldered out of the board, and can be replaced. Open your TV, locate it and resolder it from the board. go with that as a sample, and buy a new one with same type and number. its number will be printed [laser markling], on its boady, and should insist on it,a s it is a critical part. Replaceing it will solve your problem. Ok
RCA F36673ET 36"... | Answered on Dec 16, 2010
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
RCA F36673ET 36"... | Answered on Nov 19, 2009
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
RCA F36673ET 36"... | Answered on Sep 15, 2009
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that if the TV is more than 3 years old, the availability of replacement parts can also be an issue. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
RCA F36673ET 36"... | Answered on Jun 18, 2009
as a general rule, vertical faults can be divided into two types: ones that cause geometric distortion (a circle will not be round) and those that simply black out a portion of the screen. the former are faults in the vertical oscillator, drive, or output stages. the latter are blanking faults. blanking faults are almost always caused by electrolytic capacitors changing value and thereby changing the timing of the pulses which blank the screen during vertical retrace. In other words, the pulses are turning off the video signals at the wrong time. the most common true vertical fault is geometric distortion and a foldover of white lines at the top of the screen. this is almost always caused by the electrolytic capacitor on or near the collector of the vertical output transistor or part of the IC which has the supply voltage (B+) on it. In the old tube days, the general rule was that bottom distortion was in the cathode of the output tube and distortion at the top was caused by a fault in the drive circuit. this may help the solution!!
RCA F36673ET 36"... | Answered on Apr 09, 2009
Hi
this is horizontal deflection issue you need to check the horizontal yoke first
Thanks!
RCA F36673ET 36"... | Answered on Mar 11, 2009
Radio Shack vende un adaptador para que conectes el juego por el lado de la antena este aparato entra por el canal 03.
RCA F36673ET 36"... | Answered on Nov 16, 2008
take hammer and give it the good ole smasharoni as hard as u can
RCA F36673ET 36"... | Answered on Jul 30, 2008
Probably needs a new tuner or something associated with the tuner.
RCA F36673ET 36"... | Answered on Jul 07, 2007
Yep i can tell you what it is. The High pitched sound is the power supply soound when its overloaded and thats because the Horizontal output transistors shorted and this happened because of the flyback transformer went bad and /or the horizontal driver coil right off the secondary of the horizontal driver transformer and then the other side of this coil connects to the base of the horizontal output transistor. The part transformer cost about 35 to 45 bucks to the dealer and the transistor cost about 15 bucks. the total repair job cost about 175 to 225.00 after all said and done and some shops even may charge more ad there labopr rates may be higher. Good Luck
RCA F36673ET 36"... | Answered on May 17, 2006
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview]
RCA Televison &... | Answered 4 hours ago
At first, you should make sure that the remote control you have, had a code for your TV brand. If yes, you can program that remote control to control your TV. Make sure it first. If there is no code said, you can't.
Programming Notes
RCA Televison &... | Answered 5 hours ago
Google (rca)(RC32E6L)(manual) without parens OR contact RCA directly to request it.
RCA Televison &... | Answered Yesterday
Televison & Video Logo
19 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
tv will not power hear high pitched
  • Televison & Video
