20 Most Recent RCA F32676SB 32" TV Questions & Answers
RCA part number 237506, available from several places. Here's one site, and here's an eBay seller. Several other sources came up after a Google search; these will get you started.
RCA F32676SB 32"... | Answered on Jun 17, 2011
You do an adjustment on the screen nob on the flyback transformer?Resolders the CRT-(tv tube) YOKE wires R,G,B connections to the main PCB board?Resolders the video board CRT-(tv tube)video board pins sockets that connect the video board and the CRT-(tv tube) together.
RCA F32676SB 32"... | Answered on Feb 13, 2011
The problem with this set is most likly the flyback transformer, the horizontal output transistor, and possibly the supply voltage resistor off the horizontal driver transformer. Its a repair a pro should only attempt, as its the Hi Voltage circuit and a TV set is not a place to experiment with or tinker in them. This repair in my area cost anywhere from $175 to $250 to repair. Good Luck
RCA F32676SB 32"... | Answered on Jul 31, 2006
Hello Franchette, for what you describe, you have been unable to see the channels or have been deleted from the list of tuning of your TV
As a first step make sure that the antenna or cable video connection is in perfect condition, if you use a decoder, check on another TV that works well, check the interconnection cables between the decoder and the TV, if you can not solve, I sent you a link so you can download the user manual so that you follow the steps of tuning and controls the connections
I hope your information is useful and you can restore the channels on your RCA TV
Greetings Franco Dosil
Hola Franchette, por lo que describes, te has quedado sin poder ver los canales o se han borrado del listado de sintonia de tu televisor
Como primera medida aseg?rate que la conexi?n de antena o v?deo cable est?n en perfecto estado, si utilizas alg?n decodificador, comprueba en otro televisor que funcione bien, revisa los cables de interconexion entre el decodificador y el televisor, si no logras resolver, te envi? un link para que puedas descargar el manual de usuario para que sigas los pasos de sintonia y controles las conexiones
Espero te sea ?til mi informaci?n y logres restablecer los canales en tu TV RCA
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/32/3132/313174-rca/d52w15.pdf?9e9bd1856ed08ad674b2cc0c44c1c491&take=binary
RCA Televison &... | Answered 2 days ago
Hello Cherie, the RCA 98090, has no HDMI output, if it has composite audio and video output, through the RCA connectors on the right side of the DVD
To see it on your TV you would have to connect a cable of three RCA (Yellow, White and Red) from the DVD, to the AV input of your TV
I hope you can see the DVDs
Hola Cherie, el RCA 98090, no tiene salida de HDMI, si tiene salida de audio y v?deo compuesto , a trav?s de los conectores RCA del lado derecho del DVD
Para poder verlo en tu TV tendr?as que conectar un cable de tres RCA (Amarillo, Blanco y Rojo) desde el DVD, hasta la entrada AV de tu televisor
Espero puedas ver los DVD
RCA Televison &... | Answered 3 days ago
Almost certainly a bad motor. Visit your local Goodwill/rummage store/yard sale for a replacement unit. Parts are almost impossible to get and the cost to repair vastly exceeds its value.
RCA Televison &... | Answered on May 21, 2019
The only remotes that turns everything off are satellite remotes.
(Dish Network, Direct TV, Shaw, and Bell)
RCA Televison &... | Answered on May 19, 2019
The one they sent is an older model by 1.
Having said that it is a very minor change so the question is "does this tv have all the functions of the F model and is the picture ok??
Yes it is a smart TV.
RCA Televison &... | Answered on May 18, 2019
You could use your untill you can find a remote to use ...its easy just check on playstore
RCA Televison &... | Answered on May 17, 2019
Hello, if there are digital audio adapters, optical or coax audio to the RCA, with this adapter, you can exit the TV from the digital output (it can be fiber optic or coax) n you enter the adapter and connect a cable with pair of RCA and the other end of this cable, two RCA also, to the input of your sound equipment
I sent you the link of an adapter
I do not suggest using the headphone output
I hope you can solve your need
Hola, si hay adaptadores de audio digital, ?ptico o coaxial a audio para los RCA, con este adaptador, sales del televisor desde la salida digital (puede ser por fibra ?ptica o por coaxial) y entras en el adaptador y conectas un cable con par de RCA y la otra punta de este cable, dos RCA tambi?n, a la entrada de tu equipo de sonido
Te env?o el link de un adaptador
No te sugiero usar la salida de auriculares
Espero puedas resolver tu necesidad
https://www.amazon.com/Optical-Digital-Converter-Support-Control/dp/B07BKX8BV7
RCA Televison &... | Answered on May 15, 2019
Televison & Video Logo
7 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
flayback
  • Televison & Video
