RCA F27242GY 27" TV
Problems with RCA F27242GY 27" TV?
Troubleshooting and Support
Solved Problems for RCA F27242GY 27" TV RSS Feed Post a New Problem
No Picture
I was watching my TV (I have a cable box hooked up to it) when the picture went out and it made a noise like when I...
2 Solutions
TV won't turn on
I hear a clicking sound like it is going to turn on but doesn't.
1 Solution
TELEVISION
TV TURN ON AND THEN INSTANTLY TURN OFF
2 Solutions
Informacion
Tv. RCA modelo F27242GY ,chasis CTC185AB3,necesito saber si alguien tiene el numero del diodo cr117 de este aparato ya...
1 Solution
RCA 27" Television
Turned off TV, came back a few hours later, turned TVon and nothing happened checked plug to make sure it was in, I was...
1 Solution
I have a audio issue with my RCA Stereo...
I think its either the 27" or 32" model but it has no sound coming out no matter what I try, where can I get...
1 Solution
Unsolved Support Problems
Unsolved Problems for RCA F27242GY 27" TV RSS Feed Post a New Problem
channels are locked
After entering into TV menu, I selected parental control "on". Than the TV was locked in a channel and I can...
Post a Solution
37 inch protron tube TV
CTC176 DEAD SET WITH NO SOUND OR PICTURE BUT HAS HIGH VOLTAGE CHECK/REPLACE CR4704,R4702 AND R4517 the TV has the...
Post a Solution
RCA older 27in color TV
The power was shut off. When it came back I could not get it to work. After trying different things it now only works on...
Post a Solution
panasonic SP43W6
Standby light is on but tv will just not come on at all. Can anybody help please? Tv is only 2 years old!!! Thank you in...
Post a Solution
rca 38" wide format tv
i have good picture when i use cable tv input, but when i switch to a video input for the dvd player, the picture starts...
Post a Solution
burnt resistor
Resistor r41710u 12 volt supply resistor is burnt in half. I would like to know what ohms this resistor is so I can...
Post a Solution
bLACK LEVEL MESSED UP
After my daughter unplugged up her playstation from the tv, the black level messed up. I had to go into the Menu screen...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Diagonal Screen Size27 Inch
Audio Features
Sound LevelerWithout Audio Leveler
Connectors
Headphone JackWithout Headphone Jack
RCA Contact Information
Main support number580-634-0151
Sponsored Links
Loading problems.
Top Experts
Ask Me
techman Guru
12 solutions
Ask Me
ladywinn Guru
9 solutions
Ask Me
team tech Guru
4 solutions
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
