20 Most Recent Air Conditioning and Heat for Chrysler New Yorker Questions & Answers
I recently bought a 1989 Chrysler New Yorker with 119,000 miles. It runs perfectly, except for the heat, there is none! I keep getting code 88. help
Hi jean,here's how to replace the thermostat,could be stuck open,not letting your coolant get hot.
1/27/2013 4:44:58 PM • Air Conditioning... • Answered on Jan 27, 2013
Is there a way to reset the Sentry Key Immobilizer
What do you mean by reset? If there is a fault, you will need to diagnose what is causing it. Is the red dot light staying on solid or blinking? SOS Diagnostics
10/19/2022 6:15:21 PM • Chrysler Vehicle... • Answered on Oct 19, 2022
I'm installing a avital model 5303l remote start alarm on my 2014 chrysler 300 need wiring diagrams
Hello Craig Williams, I always insist .. (encourage) owners to get their manufacturers FACTORY shop manuals.. or to use professional grade documents... Not always practical ... There is an excellent FREE site which includes job times, (TSBs) technical service bulletins and original SCHEMATIC Circuit Drawings for most popular USA market vehicles... Registration is required (as these are real documents)... Click the like below: BBB Industries: BBB Industries Premium Alternators Starters Power Steering Products My only caution... Every time you return from a CIRCUIT DRAWING... The webpage puts you BACK into TSB mode... You must click back into "WIRING DIAGRAMS"... I find that odd little anomaly quite annoying. Hope this is useful. Carnac the Magnificent
12/30/2017 2:43:16 PM • Chrysler Vehicle... • Answered on Dec 30, 2017
What is salt spray?
Spray from the ocean
10/25/2017 3:01:57 AM • Chrysler Vehicle... • Answered on Oct 25, 2017
2answers
How to replace exterior door handle on a 2010 chrysler 300
Remove inner trim to gain access to the nuts on door handle.remove rods that go down to latch/lock assembly. Window must be up .
12/2/2015 10:01:22 PM • Chrysler Vehicle... • Answered on Dec 02, 2015
Location of the body control module on a 2000 chrysler cirrus
usually around the steering wheel it is the body control module so it controls turn signals and headlights
2/14/2015 4:23:12 PM • Chrysler Vehicle... • Answered on Feb 14, 2015
Chrysler voyager 2001 loosing power as i'm driving
Sounds like you may have a fuel filter plugging or pump going bad..have the fuel pressure Checked with the switch in the on position...the have the filter changed it should be in line along side the frame under the car..then check tne pressure again..if it is higher the pump is ok if not the pump is probably bad..it is inside the tank..somewhat of expensive to change $ 300 or so...good luck..
1/6/2015 8:17:35 PM • Chrysler Vehicle... • Answered on Jan 06, 2015
2006 chrysler pt cruiser timing belt diagram replace
Do you have the belt fully exposed and ready to replace? If so here is the routing and timing..first make sure the timing marks on the crank and block are matched by turning the engine by hand and that when you place the belt on the two camshafts the timing marks point directly at each other..may need some help here due to spring pressure on the valves.now the belt route, starting at the crank sprocket and going to the right..the belt goes over to and around the water pump drive the upwards and behind a idler pulley then up and around both camshaft gears then downward and behind the belt tensioner and then back to the crank sprocket...at this point you will see the belt is very close to itself just above the tensioner...and the idler..once in place, you will need a 3 and 6 mm Allen wrench to adjust the tensioner..if the timing marks point at each other on the camshaft gears and the crank and block..you are good to go to put the parts back on...as advice Since you are down that you might as well change the water pump as they are proned to go about the same time as the belt. Not required but may save double work and labor cost later..hood luck..
1/6/2015 5:30:58 AM • Chrysler Vehicle... • Answered on Jan 06, 2015
FRONT BLOWER MOTOR RESISTOR LOCATION 2007 TOWN AND COUNTRY
Most of the Chrysler products have the blower motor resister located on the passenger side firewall under the hood. You may have to remove the wiper arm and cowl grille..has a snap on wiring harness and it is fairly easy to replace once you get to it. There are two different types, one for air contition and one for non air...make sure you get the right one they are not inter changeable.Good luck..
1/6/2015 5:05:38 AM • Chrysler Vehicle... • Answered on Jan 06, 2015
Where is the valet switch in a pt cruiser
There is no valet switch in a factory system. If you have an aftermarket system, the valet switch could be anywhere the installer chose. You may have a faulty ECU. The ECU that controls door locks will depend on the model year of your PT. SOS Diagnostics
1/3/2015 4:52:43 AM • Chrysler Vehicle... • Answered on Jan 03, 2015
My 2009 chrysler sebring wont start a little red dot blinks when try starting it
The red dot indicates a fault in the immobilizer system. You will need to find someone with a scan tool to read fault codes in the PCM and WCM (immobilizer module) to narrow down the possible causes. It could be faulty wiring, a faulty key or a faulty WCM module. If there is no one local to help you, you can mail parts to a service like SOS Diagnostics.
1/3/2015 4:50:38 AM • Chrysler Vehicle... • Answered on Jan 03, 2015
2answers
No spark on 2002 pt cruiser-battery good ...found relay in circuit center under hood , switch it out with the horn fuse and it worked(?) how do I test coils and/or what else is in line of fire to engi
I have a Pt Cruiser Turbo and found that one of the plugs keeps working itself loose in the first cylinder.
11/26/2014 11:35:37 AM • Chrysler Vehicle... • Answered on Nov 26, 2014
Power steering fluid leaks
Check all the lines where they connect
10/9/2014 3:17:32 AM • Chrysler Vehicle... • Answered on Oct 09, 2014
1997 Chrysler cirrus tensioner pulley
If you have never done this before, it would be wise to pick up a service manual from the part store for you vehicle.. this will tell you how and what tools are needed
9/30/2014 2:24:25 PM • Chrysler Vehicle... • Answered on Sep 30, 2014
What is the firing order for a 2011 dodge grand caravan 3.6l?
1-2-3-4-5-6 2000 Chrysler Grand Voyager SE 3.3L R Gas engine. Here's the spark plug firing order or how to put the spark plug wires back on information: When standing on the passenger side of the van, where the fan belt is, the pistons on the left side or back of engine, are numbered 1, 3, 5 (1 is closest to you, 3 in middle, 5 is on drivers side). On the right side of the engine, or front of the van they're numbered 2, 4, 6 (2 is on passengers side, 4 is in middle, & 6 is on drivers side). The coil pack on my van is already numbered, just brush the dirt off and put the number 1 piston's spark plug wire to the #1 pin on the coil pack, etc. In case yours isn't numbered, here's the numbering of the coil pack from top left, across to the top right is 3, 1, 5, and then from bottom left, to bottom right is 6,4,2.
7/30/2014 1:46:51 PM • Chrysler Vehicle... • Answered on Jul 30, 2014
2011 dodge grand caravan 3.6l firing order
You can find the firing order for any engine on wikipedia.
6/12/2014 2:07:51 PM • Chrysler Vehicle... • Answered on Jun 12, 2014
Chrysler 30 hp (1980) runs fine in the beginning but once run for a few min it loses power then wont idle
Have you tried draining the gas out and adding new gas? You may have bad gas or water in the gas.
12/8/2013 10:51:45 AM • Chrysler Vehicle... • Answered on Dec 08, 2013
Shutting off the horn . Its to loud late at night
Disconnect the connector from the horn itself, or stuff a rag into horn to muffle sound.to make it even easier put a switch into one of the wires going to horn to shut it off at night. Don't forget to remove rag in the morning.
10/27/2013 4:04:30 PM • Chrysler Vehicle... • Answered on Oct 27, 2013
Air Conditioning and Heat for Chrysler New Yorker Logo
1 questions posted
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
deton8 von Splosion
john h
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chrysler Vehicle Parts & Accessories
Most Popular Question
recently bought 1989 chrysler new yorker
  • Vehicle Parts & Accessories
