20 Most Recent Samsung TXJ1366 13" TV Questions & Answers
No. If it's cable, the cable operator is responsible for your channel line up.
Samsung TXJ1366... | Answered on Feb 10, 2013
Check this link to download the user manual.
Samsung TXJ1366... | Answered on Jul 28, 2012
The original remote has an infrared sensor that you point to the tv "looks like a led except it see through" it has become defective and must be changed, some service shops may carry some, also try Radio Shack.
Samsung TXJ1366... | Answered on Feb 06, 2011
seems like you are having some problems in the power section of the tv. they are either one capacitor gone bad or some of them gone bad. do you know how to check capacitor? if not just take it to a repair man. good luck
Samsung TXJ1366... | Answered on Sep 14, 2007
First, I'm not a Sam Sung representative.
* check your warranty. Call for service.
*** The following is for information only.***
* Common Sam Sung TV issues; https://www.youtube.com/watch?v=9WOyR_UaBDM
* Customer's solution (from Samsung); https://www.youtube.com/watch?v=d5WwsbATsy4
* Lady's solution ; https://www.youtube.com/watch?v=rRjbxpoQQBE
* Still have problems? Call for service.
Aloha, ukeboy57
PS, The following links are for repairs that will VOID any warranty.
* Customer's repair (very Technical! Not warnings.); https://www.youtube.com/watch?v=wEWzYLaKdgU
* Another customer repair; https://www.youtube.com/watch?v=T6FmYo1fACk
* Standby like on but won't turn on; https://www.youtube.com/watch?v=tqvjkq5vSmw
* Clicks but not turning on; https://www.youtube.com/watch?v=egNSzoH4tRc
* No click at all; https://www.youtube.com/watch?v=q1cPPA9Q5yw
Samsung... | Answered 7 hours ago
That's really odd that a power outage did that. I would try unplugging the TV, hold the power button for 10-15 seconds and then leave it unplugged for an hour and come back and try it again, that will for sure reset everything by removing power from it. If that doesn't have any effect then its possible the mainboard got damaged by a surge.
Samsung... | Answered 2 days ago
The inverter broad is part of the power broad.
Its probably a bad T-Con board as long as the screen itself isn't physically damaged, no cracks, etc. But if the T-Con board won't fix it then its not worth fixing, its going to be hard to get a replacement LCD panel, if not expensive compared to a new TV. If the T-Con board is cheap enough it might be worth a shot to try that, and if it doesn't fix it then its time for a new TV. Sad but true on these!
Samsung... | Answered 3 days ago
Power supply fault. Repair the power supply.
Bad cable! How does TV attach to the satellite receiver? Coax, RGB, etc:? Try another cable first and foremost. If the cable is DB15 one bent pin in connector will cause exactly what you have described. Always check cables first!
Samsung... | Answered on May 17, 2019
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view by Mobile or by a desktop to see the search box. Mobile view has no search box.}
Could be an open internal fuse or power supply failure
Samsung... | Answered on May 16, 2019
Samsung TXJ1366 13" TV Logo
9 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
late turn
  • Televison & Video
