20 Most Recent Samsung DynaFlat TX-P3064W 30" TV Questions & Answers
it is due to your VIF OR TUNER section has stopped working due to no supply or some parts gone defective. some times it is due to signal absent from the source from you are getting. good luck.
Samsung DynaFlat... | Answered on Jul 29, 2012
Check the connections. If connections to RGB has conected wrong, this type of fault will occur. Follow the color codes of wire ends both at tV and DVD.
Samsung DynaFlat... | Answered on May 28, 2012
Had to reset the TV and re-tune all channels. But it worked.
Samsung DynaFlat... | Answered on Feb 02, 2010
Could be a bad flyback giving its making some noise, I would not be turning this on anymore :(
If its worth $95 bucks to you I would take it to the local tv repair shop to get a new flyback put in.
thanks i hope this information does help please do click the accept button to credit me for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Samsung DynaFlat... | Answered on Jan 02, 2010
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Samsung DynaFlat... | Answered on Nov 03, 2009
yes any tv repair shop can do it easily
Samsung DynaFlat... | Answered on Oct 23, 2009
then need to be gone service. i think colour circle may have changed.
Samsung DynaFlat... | Answered on Oct 10, 2009
Ur board is short,tries to unplug everythings clean it wait couple hours plug back in.If this still hapen, it ur board it bad need it to be replace.
Samsung DynaFlat... | Answered on Aug 25, 2009
This is an older tv. Generally, yes the power supply would not be an issue but possibly it is, any part can fail and the power supply does make a low noise. Probably, the High Voltage board is the issue though and should be tested. I am going to let you know right now that if you want to repair it, it just won't be worth it especially if you aren't electronically inclined since shops will charge $50 just to look at it. A new LCD tv would probably be in your interests, especially with how electronics are always getting cheaper and cheaper.
Benjamin
Samsung DynaFlat... | Answered on Jul 15, 2009
I HAVE A SAMSUNG HD TV MODEL TX-P3064W AND I TURN IT ON AND GOT ALL OF THE COLORS IN PSYCHODELIC MODE. I NEED TO KNOW IF THIS IS AN EASY AND CHEAP FIX?
Samsung DynaFlat... | Answered on Mar 04, 2009
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Samsung DynaFlat... | Answered on Sep 16, 2008
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
Samsung DynaFlat... | Answered on May 27, 2008
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Samsung DynaFlat... | Answered on Mar 22, 2008
Washing TV where in a bathtub.. Oh man Tvs cant be washed in a sink or a bathtub.??
Samsung DynaFlat... | Answered on Mar 09, 2008
VERY common on this set, in fact we did three just last month...
Replace Fjl6920 - subs to 2sc5144 or NTE2661
Replace flyback Samsung P/N# AA26-00225A
Bill
Samsung DynaFlat... | Answered on Feb 09, 2008
you have a picture tube problem, or bad capacitors in the screen circuit. I'm afraid not a job for the end user. A repair shop should be able to assist you in this repair. good Luck
Samsung DynaFlat... | Answered on Jun 11, 2007
Fixya is unable to suggest sources for that Samsung power board or any Samsung parts.
Samsung... | Answered 14 hours ago
Samsung DynaFlat TX-P3064W 30" TV Logo
Popular Tags
21 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
broke cable connector input fixed
  • Televison & Video
