Samsung LW20M11C 20.1 in. LCD Television
Problems with Samsung LW20M11C 20.1 in. LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Samsung LW20M11C 20.1 in. LCD Television RSS Feed
View More Results for Samsung LW20M11C 20.1 in. LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Samsung LW20M11C 20.1 in. LCD Television RSS Feed
Answer
Samsung LW20M11C 20.1 in. LCD Television - power supply board (including inverter cct) Power supply... (More)
Answer
Sir, Ihave a SAMSUNG model no. LA-20S51BP LCD tv,not working AUDIO VEDIO input. IF connecting with... (More)
Find a Manual
Samsung LW20M11C 20.1 in. LCD Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for LW20M11C 20.1 in. LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Samsung LW20M11C 20.1 in. LCD Television
Write a review:
Rate this product:
Would you recommend the LW20M11C 20.1 in. LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Samsung LW20M11C 20.1 in. LCD Television
Key Features
Screen Size
20.1 inch
Flat Panel Type
LCD
Display Resolution
1024 x 768 pixels
Display Capabilities
Aspect Ratio
4:3
Built-in Tuner
NTSC · PAL · SECAM
Remote Control
Remote Control
Standard
Image Quality
Contrast Ratio
500:1
Pixel Pitch
0.6375 mm
Brightness
450 cd/m²
Viewing Angle
160
Audio Features
Audio Type
Stereo
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
Without PIP
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Composite x 1 · Audio (RCA) x 1 · RF x 1 · S-Video x 1 · 21-pin Scart x 1
Screen Text
OSD Languages
English · French · Spanish · German · Italian · Dutch
Channel Labels
With Channel Labels
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 3 Watt
Dimensions
Depth
3.54 in.
Height
16.81 in.
Width
23.39 in.
Weight
21.62 lb.
Warranty
Overall Warranty
1 Year
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
