I have the Samsung 46 in Flat screen. The last few days the t.v has been taking a while to turn...
(More)
I have the Samsung 46 in Flat screen. The last few days the t.v has been taking a while to turn on... Sometimes we have to unplug it and try turning it back on... You can hear the t.v. click on and off, but the picture will not come on....
I have a 46" LCD Projection TV. I turned it on the other day and I have sound but no picture....
(More)
I have a 46" LCD Projection TV. I turned it on the other day and I have sound but no picture. After a few minutes the picture comes on but is badly distorted. Also it has little or no responce with or without remote. It wont even cut off. Had to unplug it. Never had the lamp replaced but would the lamp cause the TV not to respond?
Good Afternoon, I have a 46" Samsung Television. Yesterday I turned it on and the screen got...
(More)
Good Afternoon, I have a 46" Samsung Television. Yesterday I turned it on and the screen got very colorful and fuzzy. The sound worked fine and after about 10 minutes it cleared itself up. About every 20 minutes or so now, the screen will turn fuzzy and colorful. We had a hurricane down here in Florida recently and the power cut off a few times. I don't know if that might have anything to do with it or not. I appreciate any help anyone could provide me. Thank you very much. Ryan Cain
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
