my sony bravia continuously loses volume and then it comes back- we can change the channel back and...
(More)
my sony bravia continuously loses volume and then it comes back- we can change the channel back and forth sometimes to get the volume on again. whats happening??? it has been working fine and it's only one year old!!! HELP!
i have a samsung 47-inch LCD t.v. model# LN-T4671F it keeps turning on and off with no picture until...
(More)
i have a samsung 47-inch LCD t.v. model# LN-T4671F it keeps turning on and off with no picture until several attemps minutes later. the problem is getting worse each time i attempt to turn on the t.v. what is the problem?
We have a 2 year old Samsung 52" LCD, on occasion when first turning on it will flicker and...
(More)
We have a 2 year old Samsung 52" LCD, on occasion when first turning on it will flicker and then lose it's picture, still has sound. From an angle, I can somewhat see image movement, yet no brightness in picture. Usually, if left off for couple hours picture will come back. Yet, this happens often enough that it is a problem, yet no one will fix it unless it is currently happening... just never know when the problem will return. Have set connected to dish receiver, and have connected new HDMI cable. Anyone know what is causing this? Thanks!
Hi I have a 1080p Samsung flat panel and the TV will turn on and then immediately shut the picture...
(More)
Hi I have a 1080p Samsung flat panel and the TV will turn on and then immediately shut the picture off. The noise still works and a little red light flashes in the corner when you push a button on the remote is there any simple fix for this problem?
When I turn it on it makes the usual chime sound and continues to make the chime sound every few...
(More)
When I turn it on it makes the usual chime sound and continues to make the chime sound every few seconds and actually never turns on.
i have a samsung le52m86bdx. when you turn it on it fires up with a multi coloured background like a...
(More)
i have a samsung le52m86bdx. when you turn it on it fires up with a multi coloured background like a spectrum and it has bold vertical lines that vary in thickness, they look like a barcode. does not always happen, sometimes turn it on and everything is ok when it is faulty the sound is fine and the problem is across all inputs and dtv channels. its only 18months old and samsung dont really care about it im not a happy camper!!! any help would be awesome, thanks
Hey can i have the screws your about to remove as my samsung tv needs some screws to attach th ebase...
(More)
Hey can i have the screws your about to remove as my samsung tv needs some screws to attach th ebase to it..lol
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
