I have a 26" Samsung flat screen HD television. I have hooked it up to my HD cable box with an...
(More)
I have a 26" Samsung flat screen HD television. I have hooked it up to my HD cable box with an HDMI wire and yet I receive only audio and not video of HD channels
My Samsung LNR2668W 26 in. HDTV-Ready LCD Television keeps turning on and off on its own and idk...
(More)
My Samsung LNR2668W 26 in. HDTV-Ready LCD Television keeps turning on and off on its own and idk why.....i have read previous ones where they say its the bulb or the power source but those were 50" tv's that were having that problem and idk if mine could be the same
My 26" Samsung HDTV keeps turning on and off on its own and idk why.....i have read previous...
(More)
My 26" Samsung HDTV keeps turning on and off on its own and idk why.....i have read previous ones where they say its the bulb or the power source but those were 50" tv's that were having that problem and idk if mine could be the same
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
