20 Most Recent Apple Watch Series 2 Questions & Answers
yes it will as long as its the same size watch face
Apple Watch... | Answered on Jul 26, 2019
There is a very good chance that the pendulum regulator wheel and rocker assembly is out of adjustment or has a bent tooth or finger that is jamming the movement.
The adjustment of this is extremely sensitive and so a slight misalignment will at some point show up when the causes of the misalignment rotate to align once again, which is why it is a periodic fault.
Despite it being a very sensitive area and in need of a light hand to remedy, for anyone experienced in working on this kind of movement, it would be a simple and speedy repair.
Unless you have experience of working with such movements, I would recommend leaving it alone and seeking help from a professional, because of the risk of making it worse rather than better, so making it more difficult to repair in the long run.
I have a 1840 Mauthe wall clock that had that exact fault, and once it was properly aligned, it has kept excellent time for the last seven years so be gentle with it.
Watches | Answered 3 days ago
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Watches | Answered on Aug 20, 2019
English only.
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn [email protected]
Watches | Answered on Aug 16, 2019
Other than contacting Versa directly and asking them where the nearest stockist of a replacement bracelet is, to your location, then the only other option is to use a specialist sourcer, such as myself.
I have a contact in Guangzhou, China who can get pretty much anything.
If you would like me to source one for you, then please EMAIL ME [email protected] and I’ll get some prices & images together for you
Watches | Answered on Aug 15, 2019
Google (smeal)(model)(manual) without parens OR contact Smeal directly.
Watches | Answered on Jul 26, 2019
To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
Check your battery and charge your Apple Watch - Apple Support
https://support.apple.com/en-gb/HT204608
Apple Watch Series 2 Logo
4 questions posted
Top Apple Watches Experts
Robek Thirtysix
Robek Thirtysix
Level 1 Expert
Jacques Carrier
Level 1 Expert
Ravi
Are you an Apple Watch Expert? Answer questions, earn points and help others
View Most Popular
Watch Apple
  • Watch Apple
Most Popular Question
battery life improved apple watch series
  • Watches
