i have att uverse and by connecting to the regular video inputs it is okay. I have also tried a...
(More)
i have att uverse and by connecting to the regular video inputs it is okay. I have also tried a different box that works and I still do not get the HD signal. Thanks
We bought the above 17inch flat screen to mount on the wall in our kitchen. The advertisement...
(More)
We bought the above 17inch flat screen to mount on the wall in our kitchen. The advertisement through Amazon said it was wall mountable and the directions have a page containing directions about using the wall mount kit (which it says is sold separately). But they don't give the name of it. There are no holes on the back that fit the wall mount kits we have. Does anyone know if there is some bracket that must first be fitted to it before using a wall mount??
We have a Samsung LTN1785W LCD TV and want to use external Bose sound system speakers with the TV...
(More)
We have a Samsung LTN1785W LCD TV and want to use external Bose sound system speakers with the TV but can't seem to find info on setting the TV to use the exterior sound system
I am trying to hook my Samsung LTN17585W that has Comcast Cable running directly from the cable...
(More)
I am trying to hook my Samsung LTN17585W that has Comcast Cable running directly from the cable outlet to the back of the tv. However, I cannot get my surround sound which is 7.1 Stereo system. Any suggestions
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
