we have a vizio digital tv and are trying to find the local channels without being hooked up to...
(More)
we have a vizio digital tv and are trying to find the local channels without being hooked up to cable. How do we do this?
Model # SMH 9151W, Serial # J4M77MTSA00951M over-the-range microwave oven has a 40 watt night light...
(More)
Model # SMH 9151W, Serial # J4M77MTSA00951M over-the-range microwave oven has a 40 watt night light w/2 brightness settings--dim and dimmer. We are use to a much brighter light for stove-top cooking. Do you have any suggestions to replacing the 40 watt light with a much brighter one?
lt-p1745 Typical power on no image. Light cycles on and off (as if it is trying to turn on but...
(More)
lt-p1745 Typical power on no image. Light cycles on and off (as if it is trying to turn on but loops) How do I figure out if it is the power board or the main board. Help. I know this is an easy fix but have no schematics. Where to start or most common problem would be helpfull lt-p1745
I have a Samsung DVD-V8600 connected to my HD TV via S-video and audio. The DVD function works fine,...
(More)
I have a Samsung DVD-V8600 connected to my HD TV via S-video and audio. The DVD function works fine, but no VCR function. I did not connect my HD Sattelite receiver to the DVD-8600, because I am not interested in recording TV on VCR tape--I jsut want to play my old VCR tapes.
samsung ln26a450c1d 26 inch when viewing tv looking up it looks like a negitive all other views are...
(More)
samsung ln26a450c1d 26 inch when viewing tv looking up it looks like a negitive all other views are normal
I have a Samsung LT-P1745 LCD monitor. The power on indicator will blink, and low clicking sound...
(More)
I have a Samsung LT-P1745 LCD monitor. The power on indicator will blink, and low clicking sound comes from speakers. What is the problem?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
