When I burn DVD with subtitles my computer shows them but my DVD player don't play and don't show...
(More)
When I burn DVD with subtitles my computer shows them but my DVD player don't play and don't show them. Film format is AVI and subtitles format is SUB-fail. And when i want to select them then the DVD player menu even won't show that subtitles is on the disc.
Hi! I have a samsung 5 DVD player which has jammed completely. Mid movie, it shut off on its own...
(More)
Hi! I have a samsung 5 DVD player which has jammed completely. Mid movie, it shut off on its own after displaying "Protection" I tried switching it back on several times but it would be on just for a few seconds then "Protection" would come back on and it would shut off. I have a DVD that I have not watched now stuck in there... Help!!
I have tried playing around 25 DVDs, out of which. One dvd plays fine but the rest of 24...
(More)
I have tried playing around 25 DVDs, out of which. One dvd plays fine but the rest of 24 dvds give a scrambled video output. Can some one please help?
THanks
Joshua
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
