20 Most Recent Samsung DVD-VR325 DVD Recorder/VCR Questions & Answers
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Samsung... | Answered on Jun 24, 2014
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
Samsung... | Answered on Mar 14, 2013
try to clean a lens with cotton buds just soft and slowly
cause lens is very sensitive.
Samsung... | Answered on Jun 01, 2010
A medium sized black box in the middle of the screen indicates the text feature is engaged.
Explanation:
For several years in the settings on many sets with closed captioning there was a option for "TEXT" and the idea was books and other written things could be transmitted on certain channels.
This never really got off the ground but millions of sets have this feature.
The TEXT box can come from one of two places:
In the set's customer menu look for CC (closed caption) and make sure TEXT IS NOT HIGHLIGHTED.
If you are using a cable or satellite box etc it can also come from that.
If you find it selected for TEXT 1 (there are 1-4 in most sets) either turn it to off or select something other than TEXT 1 and the box should go away. It could also be coming from an external source of something else connected to the set but this is not likely.
Check first CC with the set's remote to see what is turned on or off and LET ME KNOW WHAT YOU FIND.
Regards, SD TECH
Samsung... | Answered on May 02, 2010
Hello and Welcome to FixYa!
You can go for universal remote. If works with all most all the popular softwares available in the market! i have checked it for Samsung. all universal remotes works for the model described.
Best of Luck,
Please Do RATE my solution, If found HELPFUL,
Concerned,
Waqar.
Samsung... | Answered on Apr 30, 2010
Buy a cleaning disc and use it.
Samsung... | Answered on Jan 19, 2010
Here you go..
1. Turn ON
2. Open Tray
3. Press Menu Button
4. Enter 57538
(region will appear in top left hand corner)
5. Enter 9 for multiregion
Jay
Samsung... | Answered on May 21, 2009
sell me your unit!
Samsung... | Answered on May 06, 2009
tell me how to record from a vhs tape to a dvd
Samsung... | Answered on Nov 19, 2008
sell me your vr325 woolletj at gvsu dot edu
Samsung... | Answered on Jan 28, 2008
my friend it is best to record your movies or music with a computer.as these DVDS Recorders are not compatible with certain types of dvd disc brand probably try another brand of dvd disc.and see what it does, try the memorex or the TDK.also dont use dvd recorders to record your movies use them to play back.they are problem.good luck.
Samsung... | Answered on Jun 23, 2007
That's really odd that a power outage did that. I would try unplugging the TV, hold the power button for 10-15 seconds and then leave it unplugged for an hour and come back and try it again, that will for sure reset everything by removing power from it. If that doesn't have any effect then its possible the mainboard got damaged by a surge.
Samsung... | Answered 6 hours ago
The inverter broad is part of the power broad.
Samsung... | Answered 12 hours ago
Its probably a bad T-Con board as long as the screen itself isn't physically damaged, no cracks, etc. But if the T-Con board won't fix it then its not worth fixing, its going to be hard to get a replacement LCD panel, if not expensive compared to a new TV. If the T-Con board is cheap enough it might be worth a shot to try that, and if it doesn't fix it then its time for a new TV. Sad but true on these!
Samsung... | Answered 16 hours ago
Power supply fault. Repair the power supply.
Samsung... | Answered Yesterday
Samsung DVD-VR325 DVD Recorder/VCR Logo
17 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
fault code
  • Televison & Video
