We moved the tv without disconnecting any of the cables into the DVD-V1000. Now when we push the...
(More)
We moved the tv without disconnecting any of the cables into the DVD-V1000. Now when we push the DVD/TV button, we get a scrambled looking screen in the DVD mode, but in TV mode everything looks fine. I've checked the cables and the channel position. What might this be?
samsung dv-5500 has the same dvd problem. it will play some discs and others will say there is a...
(More)
samsung dv-5500 has the same dvd problem. it will play some discs and others will say there is a disc error.
I have 3 t.v's. My Samsung 850 is the only one that does not show picture and has "Weak or No...
(More)
I have 3 t.v's. My Samsung 850 is the only one that does not show picture and has "Weak or No Signal" messages display. My kids were trying to switch from HDMI1 to AV1 to show dvd player, but I think they may have clicked the wrong buttons not understanding fully how to switch. DVR still works but T.V(HDMI1) cannot connect. The mode is currently on t.v., channel is 3. I tried running Antenna==>Auto Program to reset channels but no change. All plugs are still plugged into the u-verse box. All other devices work 2 other t.v's, internet, ip phone etc, so I believe I'm just not finding the right screen menu options or following correct steps. Can you help?
i can not record tv programs with my cable tv because i do not know the vcr code i need to enter...
(More)
I CAN NOT RECORD TV PROGRAMS WITH MY CABLE TV BECAUSE I DO NOT KNOW THE VCR CODE I NEED TO ENTER WHEN ASKED FROM SET-UP SETTINGS,I HAVE A SAMSUNG DVD-V1000 COMBO DVD/VCR PLAYER.
My player is an original installation in a 2003 Chevy Suburban. The player only accepts Area code 1...
(More)
My player is an original installation in a 2003 Chevy Suburban. The player only accepts Area code 1 (US), while I would like it to play Area 2 (Europe). (Or of cource Area 0/zone free if possible) Serial number: 112545 Ref. Number: 15191409 Produced: November 2003 If anyone has the code for this player, you would certainly make me and the back seat noise makers very happy! Regards, KAP
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
