I have a DVD-HD931 Samsung and the power will not come on. The 1.0 amp fuse is good. Any ideas? I...
(More)
I have a DVD-HD931 Samsung and the power will not come on. The 1.0 amp fuse is good. Any ideas? I don't have a service manual. I have a VOM.
Samsung DVD Player - HD 931 turns on, does not respond to buttons either manually or via...
(More)
Samsung DVD Player - HD 931 turns on, does not respond to buttons either manually or via remote...the display reads 'play or loading or open' but nothing happens. last used two months ago...any ideas what might be the malfunction?
hi there, is there any way to unlock this DVD player for code free use? Thanks for the help....
(More)
hi there, is there any way to unlock this DVD player for code free use? Thanks for the help. Christine
I have a Samsung DVD-HD931 player, and I have had it for sometime. I am trying to watch a dvd and I...
(More)
I have a Samsung DVD-HD931 player, and I have had it for sometime. I am trying to watch a dvd and I have sound but no picture. I have checked all the connections, but still no pict. There were several buttons on the remote pushed and now no pict. Is there a setting on the dvd that could be causing this?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
