20 Most Recent Hitachi HSB40B16 40 inch Bluetooth-Enabled Sound Bar Questions & Answers
Some TVs require you to set it to external speaker in the menu and then raise volume as required.
Hitachi HSB40B16... | Answered on Dec 03, 2015
Hello Ricardo, for what you comment, you would have a fault in the exit stage of your Hitachi
Test, with the equipment turned on, operate the keys of System A or System B and in doing so, you should hear, inside the amplifier, the noise produced by the relay speakers, if you do not hear it, it would indicate the fault in the exit stage
There may be a channel or both channels wrong
I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Ricardo, por lo que comentas, tendrias una falla en la etapa de salida de tu Hitachi
Prueba, con el equipo encendido, accionar las llaves de Sistema A o Sistema B y al hacerlo, deberias escuchar, en el interior del amplificador, el ruido que producen los rele de conexion de parlantes, si no lo escuchas, indicaria la falla en la etapa de salida
Puede estar un canal o los dos canales mal
Te sugiero buscar un servicio tecnico especializado
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Hitachi-HA-6-Service-Manual.pdf https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Hitachi-HA-6-Schematic.pdf https://www.radiomuseum.org/r/hitachi_ha_6.html
Hitachi Audio... | Answered on Jun 18, 2019
Hello Andi, I sent you the link so you can download the user manual
I hope that you can solve your concern
Hola Andi, te envio el link para que puedas descargar el manual de usuario
Espero Que puedas resolver tu inquietud
https://data2.manualslib.com/pdf5/112/11111/1111069-hitachi/axm649bt.pdf?778bbd45e1ee17ba493e1c672ab8ba37&take=binary
Hitachi Audio... | Answered on May 20, 2019
Download the service manual and read it. Regards,
Serge.
Hitachi Audio... | Answered on Feb 12, 2019
The power supply could be failing.
Hitachi Audio... | Answered on Feb 02, 2018
check with Hitachi . we do not have parts
Hitachi Audio... | Answered on Jan 31, 2018
Just go to the shop
Hitachi Audio... | Answered on Sep 17, 2017
Try Googling (hitachi)(kc50)(manual) without parens to determine whether dimming is possible and how to do it.
Hitachi Audio... | Answered on Jun 20, 2017
Hitachi HSB40B16 40 inch Bluetooth-Enabled Sound Bar Logo
1 questions posted
Top Hitachi Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Carlos Oliveira
Are you a Hitachi Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Audio Players & Recorders
Most Popular Question
bluetooth connects but not sound not
  • Audio Players & Recorders
