20 Most Recent
Engines & Components for Mazda B2200 Questions & Answers
Sir I'm over rolling my Mazda engine can I also change new piston
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
1/28/2019 10:46:15 AM •
Engines &...
Answered
on Jan 28, 2019
How do I change the battery for my keyless remote entry for my 2010 Mazda CX-7?
Do you mean for the key fob or for the unit mounted in the vehicle? The key fob has either a screw in the back, or it snaps together. Take the battery to the jewelry counter at Walmart and they'll give you a replacement. If you mean the unit mounted in the vehicle, it is powered buy the vehicles battery. It may have an internal battery for memory retention, but it would void the waranty taking it apart to replace it.
Power steering belt mazda lantis
Do u want the location, what size or how to? "Haynes manual" at your local auto parts store is a life saver for anyone w/ a vehicle. I have one for all 3 vehicles we have.
I need heater motor for a e2200 a mazda 01
Your local automotive store should have it or should be able to order it, they can usually have it the next day or if you go early enough they might can get it before they close.
Torque settings
establish a right angle center line of the head and work from one side to the other side of the center line one bolt at a time. back and forth till you cover all the bolts twice over. never more than 85 ft lbs of torque on each bolt. I usely go to 65 lbs and then 85 lbs. If your not to sure of this answer use your computer to find the proper torque for your head, but this is the way I been doing for on and about 50 years.
Bleed air out cooling system
The air within the radiator should bleed out naturally after you've run the car up to operating temperature. Allow the car to cool off before removing the radiator cap and refill until full; as the radiator fluid circulates throughout the system, the excess air will rise to its highest point which is the expansion tank or radiator cap. Most radiator caps are located on the expansion tank but do not open the cap when hot due to the pressure build up within the system; if you're not sure if it's cool enough use a large rag or towel and cover the cap in case of pressure release.
