20 Most Recent
Hisense SmartTV Wireless Connect HiMedia Questions & Answers
I have a mag 254 iptv and a Hisense TV. The remote codes clash and the two are unusable in tandem. Can the remote control codes on the Hisense be changed?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; to which you want set-up codes; in the "
Search box at the top right of the display window" to get gathered related posts.
3/27/2024 7:09:19 PM •
Hisense...
Answered
on Mar 27, 2024
How can I re-program Hisense TV remote control / model EN - 31201A
Often the instructions for programming a TV remote control is included in the TV manual. The EN 31201A remote came with several TVs including the Hisense F39V77C. The manual for this TV only lists a few cable and satellite box codes:
https://www.manualslib.com/manual/594196/Hisense-F39v77c.html?page=11#manual . This page refers you to the manufacturer's site for additional codes. The Hisense-usa.com site did not list the specific TV that I found that used the EN31201A remote.
Since the F39V77C first shipped in 2012, the remote would probably be limited to use with devices that were built in 2011 or earlier. I recommend a universal remote that includes support for streaming devices. Unfortunately, I don't know which support Fubo TV specifically. Most packaging advertises Roku or Amazon Fire support. You can find the code lists for some RCA universal remotes online. (Most of the others require finding a code written inside the battery compartment to determine the remote generation and code list.)
I wish that I had better news for you.
12/13/2023 10:57:09 PM •
Hisense...
Answered
on Dec 13, 2023
How can i do a bypasson a circuit board that was struck by lightninh on a tv?
Bypassing a board or a part on the board would be like removing the spark plugs from a car and expecting it to run. On a serious note, if the TV has lightning damage recycle it and buy a new TV, you may be able to turn in a claim to your insurance company, once a set has storm damage even replacing a board may not fix it long term, in our service center we usually won't repair a TV the customer advises of lightning damage,it's a good way to get call backs
11/28/2023 2:13:00 AM •
Hisense...
Answered
on Nov 28, 2023
HISENSE ANDROID TV MODEL:70H6570G,HELP!!!!!
Question edited to fix lack of spaces (dozens of them).
Is the keyboard you used to type this connected to the television. It is not making spaces. Look at this section you typed!
Low,I've gone through&attempted to delete apps1by1,w/remote,but they always reappear after it's powered back on,I've also cleaned each app.cache individually,attempted a hard factory restart w/remote,which did nothing@all. I'm unsure what to do now to get the issues resolved??
You need a new keyboard because if it is faulty, it has the ability to cause issues not related to just typing! Hisense are a cheap and nasty brand at the budget end of the market and are well known for reliability issues. Doing a hard reset of the Android Operating System should have fixed your issues.
You could contact their Support, we aren't them, we are Fixya dot com.
https://www.hisense-canada.com/en/support-2/support
8/26/2023 12:44:29 PM •
Hisense...
Answered
on Aug 26, 2023
HISENSE 58R6E 58" Television, lost picture and sound.
Where did you buy the boards? Shop Jimmy is the only reputable seller of television parts. This Tip I wrote explains the issues. Hopefully, our Television Expert Larry will be along soon.
https://www.fixya.com/support/r29790007-repairing_own_television
Shop Jimmy
Hisense 58R6E Parts ' ShopJimmy
shopjimmy.comhttps://www.shopjimmy.com
The Online Leader In TV Repair And Replacement Parts. Check Out Our Huge Inventory Today! 180 Day Warranty. TV Repair Made Easy. Repair Kits Available. Servicing All TV Brands. Highlights: Newsletter Available, Multiple Payment Options Available.
TV PartsTV Boards, Cables, Lamps, Remotes, Speakers, Stands, Tools, And More!
TV ComponentsScrews, Capacitors, Diodes, Fuses, ICs, Resistors & More TV Components
TV Stands & MountsWe Have A Variety Of Universal Stands & Mounts For Every TV Set!
Hisense 58R6E Parts
ShopJimmy
https://www.shopjimmy.com > Brands > Hisense
Shop our high-quality replacement parts to repair your Hisense 58R6E.
6/28/2023 5:24:22 PM •
Hisense...
Answered
on Jun 28, 2023
I have a Hisense model 50h5c sound black screen flashlight test image on half lines on other half screen is on right what parts do you think I need
Based on the symptoms you described for your Hisense model 50h5c TV, it seems that there may be a hardware issue affecting the display. Without being able to diagnose the TV in person, it is challenging to pinpoint the exact parts that may need replacement. However, there are a few components that commonly contribute to display issues:
T-Con Board: The T-Con (Timing Control) board controls the timing and signals sent to the display panel. If there are issues with half of the screen or black screen with half lines, a malfunctioning T-Con board could be a potential culprit.
Display Panel: The display panel itself could be defective, causing the black screen or half-line issue. Unfortunately, replacing the display panel can be costly and often not cost-effective compared to purchasing a new TV.
Main Board: The main board handles various functions of the TV, including signal processing and overall control. In some cases, issues with the main board can cause display problems.
6/28/2023 2:34:15 AM •
Hisense...
Answered
on Jun 28, 2023
