20 Most Recent Hoover Power Path Pro Advanced Carpet Washer Questions & Answers
WD 40 !!!!!! The plastic assembly connected to the spray trigger tends to get dry and stick.
Hoover Heating &... | Answered on Apr 14, 2014
Press the up button :>)
Heating &... | Answered 11 hours ago
Before ignitor is energized there are several safety limits that must be operating correctly, one of which is usually a flame roll out/temp limit switch. This switch will have little red push button on back side. Power off unit, unplug or turn off breaker so no power to heater and verify no power. If you see thos switch push reset, if you feel it click then power back on and then try it. If it happens again or if you don't see manual reset switch then call a professional.
Heating &... | Answered 17 hours ago
Fault F2 is an indoor temperature sensor fault. There may be a problem with the sensor, the wiring between the sensor and the circuit board or the circuit board.
Heating &... | Answered 20 hours ago
Hoover Power Path Pro Advanced Carpet Washer Logo
3 questions posted
Top Hoover Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Hoover Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Heating & Cooling
Most Popular Question
will not pick up water fix
  • Heating & Cooling
