20 Most Recent Samsung HC-P4363W 43 in. TV/DVD Combo Questions & Answers
Check the tv out?If the tv have picture,colors R,G,B misalignment,picture have colors shadows,look like 3D pictures.The tv problems is it have a convergence problems.Very common on a DLP tvs.Very much repairables.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Samsung... | Answered on Oct 27, 2018
When u decide its not good
Samsung... | Answered on Nov 26, 2014
It's one of two video formats. See... http://ihffilm.com/videostandard.html
Samsung... | Answered on Jul 10, 2014
Try to reinstall after shake your new toner.
I did sometimes and it actually works!
Samsung... | Answered on Mar 25, 2014
Typically, these type of devices have a small hole where you can put in a paperclip to manually eject the CD drive / DVD slot. Hope that helps!
Samsung... | Answered on Sep 27, 2013
You might have a problem with the intenal board or the AV connection onto the board. Have a TV repair center check the board and the connection.
Samsung... | Answered on Apr 29, 2012
You have this listed under tv combos (sets with a picture tube and a vcr or dvd unit built in.
They have little or no adjustments for convergence---
If set is another kind---let me know brand and MODEL number so I can try to assist you.
Samsung... | Answered on Mar 23, 2012
The power supply and switch are bad. It needs a repair.
Samsung... | Answered on Mar 15, 2012
The tv have a problems,known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D picture look alike?Yes.The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Samsung... | Answered on May 25, 2011
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Samsung... | Answered on Apr 15, 2011
In this tv - Samsung HC-P4363W - the image is projected by 3 small tv tubes - if the image is perfectly fine with the exception os a small line in which it's missing then the defect is in the image processor: the memory buffer has a defective cluster so the part stored there is not picked up.
Since the buffer is integrated in the processor circuit, which is glued on the mainboard, it means that the entire board will have to be replaced. Unfortunately this is an old model for which spare parts are no longer manufactured - so your only hope will be in finding one on auction sites.
If your tv is a different model and you have put it by mistake in this section then, in all models and types, it's a defect in the image generator: a row of pixels is no longer commanded - the only way to fix that is to replace the defective part.
In an LCD or a plasma the defect is in the screen panel and it means that the tv is unfixable - replacing the screen would cost more than a new tv.
In an DLP projection tv the part that failed is the DMD circuit and it can be replaced but it's a very expensive part and the labor to install it is very complicated ant it should be done only by an experienced repairman. Depending on the exact model of your tv it will cost you between $500 and $800.
Samsung... | Answered on Mar 07, 2011
With most laptops, the external VGA connector needs to be "turned on". Usually the keyboard command is Fn+F5, or maybe Fn+F4. check your laptops user manual to figure out how to activate it. Also Im not sure what resolution must be, but it might need to be set to 640x480 for component cables to work. thats in the display properties. Hope this helps
Samsung... | Answered on Dec 26, 2010
You can just replace the convergence board which for your model is part # BP95-00415C They are under $100 dollars and are just a plug in board. You should be able to purchase from
www.partstore.com
Samsung... | Answered on Sep 01, 2010
This is a problem with your convergence settings found under your tv's menu. its very easily fixed, you just need to open the setting for convergence and use the arrows on your remote to adjust. inproper convergence can cause either a red or blue haze around almost any object displayed on the tv screen
Samsung... | Answered on Apr 14, 2010
Tries Websites Tv repair World.com,Tvrepairkits.com,Ebay.com to check the FBT to buy refurbish parts.
Samsung... | Answered on Mar 19, 2010
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
75 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
convergence wrong fix
  • Televison & Video
