20 Most Recent Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates Questions & Answers
Go to the Garmin website. If you have an account, log in. If you do not have an account, then make one. The site will allow you to register your device onto your account. You can then download and install Garmin Express, which will provide you with any software and map updates. To use Garmin Express, just plug your GPS into your PC, open the program, and follow the instructions it provides.
Garmin nuvi... | Answered on Apr 06, 2017
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You should leave your GPS plugged into the PC overnight to give it a chance to charge if the battery is flat.
You should talk to only them where you have bought this. Not fixya not facebook will help you.
Garmin nuvi... | Answered on Feb 17, 2017
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Garmin nuvi... | Answered on Mar 08, 2016
Send it back to Garmin. It needs a new internal battery. They do wear out. It may be a warranty repair.
https://my.garmin.com/rma/en-US/repair/repairLanding
Garmin nuvi... | Answered on Jan 12, 2016
Chinese may not be offered as a language option on the 1300.
Garmin nuvi GPS | Answered on Jan 14, 2019
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
Garmin nuvi GPS | Answered on Mar 20, 2018
You may have inadvertently blown the fuse to the cigarette lighter on the truck, I would check there first before doing anything else
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Garmin nuvi GPS | Answered on Jun 10, 2017
http://download.garmin.com/omt/express/GarminExpress.exe
Install, plug in gps, it will ask for your key and download and install the map update. Do this before bed or if your not using the PC for a few hours.
Garmin nuvi GPS | Answered on May 09, 2017
Charge it overnight with a high power usb charger, 2A or greater. If it works properly the next day, the issue is with your vehicle charger. If it is still not working, reposition the ribbon cable that the battery connects to.
Garmin nuvi GPS | Answered on May 02, 2017
Normally on the lower back section of the unit, there will contain the model and serial number of the item in question. Additional information can then be found on the "Garmin" web site.
www.garmin.com
There you will find additional information with updates and operation manuals for your product(s).
Carefully, very carefully lest you break the ribbon that connects the front of unit to the back of it. Let someone else do it for you is a better idea.
Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates Logo
7 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
not plugged into power supply will not
  • GPS
