I have a samsung pcl541R. I thought I was having a convergence problem so I ordered a new...
(More)
I have a samsung pcl541R. I thought I was having a convergence problem so I ordered a new convergence board model AA41-00340C. I repalced the cards and (think) I reconnected all the wires as originally connected. I turned on the tv and the colors were better but seemed to pulsate. I attempted the auto focus with no luck and the tv shut itself off automatically after 90 seconds or so. I tried several times and was unable to get the screen to focus. I found some guidelines on resetting some memory using the remote and brought up a screen that looked like a giant checkerboard. I attempted to get out of this screen and now have perfect sound and no picture. Please help.
samsung tv model #PCL5415R made in nov. 2002 have sound but no picture could it be whats call a...
(More)
samsung tv model #PCL5415R made in nov. 2002 have sound but no picture could it be whats call a flyback
i have a samsung projection tv, when connected to the cable coaxial the picutre is fine, but hen...
(More)
I HAVE A SAMSUNG PROJECTION TV, when connected to the cable coaxial the picutre is fine, but hen using rgb cables for hi def the picture is ghosted.. cant seem to figure it out
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
