20 Most Recent Samsung HCM553W 55" Rear Projection Television Questions & Answers
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Samsung HCM553W... | Answered on Dec 29, 2011
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Samsung HCM553W... | Answered on May 15, 2010
Ur tv have convergence problems,it dead.U must know how to solders?U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a covergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Samsung HCM553W... | Answered on May 03, 2010
Convergence is dead.Know how to solders? Replaced the 2 convergence ICS and some or all it resistors will solved this problems.Tries Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Samsung HCM553W... | Answered on Feb 23, 2010
What makes you think Blue tube is Bad ,It may just need coolant fuild changed out.
Samsung HCM553W... | Answered on Feb 19, 2010
Try removing the AC power cord from the wall, then press and hold the power button for 30 seconds or so, then plug it in and try it again. This may reset the timer to default off position. Otherwise unplug it overnight to make sure all the capacitors have fully discharged then plug it in and try again.
Good Luck
Dan
Samsung HCM553W... | Answered on Dec 10, 2009
You are going to have to reconverge your TV. Order a service manual and it has a 20 page set of instructions on how to set up the convergence for the first time with new convergence amplifiers. Once you have done this procedure the "perfect picture" one touch control should be enough to keep it in convergence. You must have the original remote control in order to do the convergence procedure.
Good Luck.
Dan
There will be two big Audio Amplifiers on the convergence board, they will say STK382 or some such STK number on them. Look for burned connections on the bottom of them and resolder any suspect connections before anything else. If that doesn't work, get an ohm meter across the various outputs and look for one of them with vastly different readings than the others and change the chip with the funky readings. Lastly look for the connection to the edge sensors on the sides of the screen about half way up. If that wire is disconnected it will give a very bad picture that is very similar to what you are describing.
Hard to tell, but my first guess is that the green or blue video amp, or guns on the picture tube have failed.
The convergence chips have gone out. It costs about $300 if it's not under warranty. This is a common problem with all rear projection tv's.
This is a very common problem with all projection tv's it is the stk392 ic's in your set have failed. You can attempt the repair yourself as long as you understand the risks involved when working inside a tv, otherwise you can get it repaired by a pro and i would guesstimate it will cost somwhere between 250 to 300 to fix. the ic's are located on a big heatsink and the number stk392-xxx xxx If xxx is beteween the numbers 110 and 180 you can use the stk392-180 for the repair, and i would recomment doing this. if it is stk392-560 or another number replace only with the same ic.
Samsung HCM553W... | Answered on Sep 02, 2009
if you have access to the color canyons then you can see one of the three is not lighting. (RED). So there is a process to know if the tube is totally inoperative or it can be saved. This process consist of trying to find the High voltage and second the video driver signal. A process difficult to do specially managing the high voltage who is really risky. be really careful to know to manage this area, a stroke can happen if you are not sure
The second area you mean divergence in reality is convergence. This area can be adjusted or repaired when three tubes can work, so go ahead with the diagnosis of the tube. or ask for a estimate in a workshop.
Samsung HCM553W... | Answered on Apr 25, 2009
Hi, convergence amps have blown, if you have soldering equipment and are proficient at soldering & un-soldering you can make the repair if not you need to calll a tv tech, there is also an alignment that must be done with the original remote once you install the IC`s, if your capable of this get back to me and I`ll look up the parts for you, video-tek
Samsung HCM553W... | Answered on Feb 25, 2009
tv image is bigger than the screen size.
Samsung HCM553W... | Answered on Oct 26, 2008
The auto focus is not actually focusing the tv. When it is running it is adjusting the convergence. Most likely the repairman that replaced your tuner didn't plug the sensor wires back in. I would call him back out and have him hook it back up.
There should be a convergence menu in the tv. Use the samsung remote and go into the menu and look for convergence.
Samsung HCM553W... | Answered on Sep 16, 2008
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Samsung HCM553W... | Answered on Apr 23, 2008
hi i dont suppose you have floor standing speakers next to it
as mine done that moved away speakers now all is fine
Samsung HCM553W... | Answered on Mar 17, 2008
Samsung HCM553W 55" Rear Projection Television Logo
24 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
auto focus problem
  • Televison & Video
