20 Most Recent Samsung HLN567W 56" Rear Projection HDTV Questions & Answers
First, try to connect ext speakers. If the sound is OK just replace speakers. Otherwise the problem in amped sound output.
Samsung HLN567W... | Answered on Feb 10, 2015
dlp chip need to be adjusted, very sensitive to adjust.
Samsung HLN567W... | Answered on Jun 20, 2014
check the color wheel
might also be the color wheel. These can make some really loud & strange noises. For this model# HLN567W Color wheel PART NUMBER: BP96-00250A
Best Buy: $85.20
Samsung HLN567W... | Answered on May 15, 2014
only a few ideas here: set will do this if lamp door or safety switch (some are activated when rear cover is removed).
A common issue when wheel is replaced is the flat ribbon cable from it to the DMD unit-----it only has connections on ONE side where it plugs in and it is possible to plug it in backwards and have no operation.
If lamp comes on for a very short time ballast is "possible".
Also make sure not a lot of dust on fans etc.
just ideas based on working on a lot of these sets.
Samsung HLN567W... | Answered on May 23, 2012
Bad Color Wheel, Common Problem with these sets.. Samsung Parts.com 1-800-627-4368
Encompass Parts Distribution 1-800-638-3328
Samsung HLN567W... | Answered on Aug 18, 2011
Yes you are right. This is indeed a problem associated with the DMD board. The Chip is not sold seperately , you have to buy the whole board.It is the large board located on whats known as optical block or light engine. The board looks like this. If you can get me the part number off the board, I can find you a replacement
http://www.ecoustics.com/electronics/forum/home-video/566786.jpg
Samsung HLN567W... | Answered on Aug 16, 2011
I had the same problem and it turned out to be the color wheel. if you dont fix it soon it will break.
here is how to replace it: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/#idc-ctools
i bought mine from amazon also for around $80-$90
part #bp96-00250a
Samsung HLN567W... | Answered on Jul 29, 2011
Problem could to be the DMD Board,if picture freezes and you still have sound, On the Inside of the DMD board resolder the rectangler Ics on the short side.This has fixed some of the TVs that do this.
Heres another thing Have you Pull the Lamp and Looked inside to see if the Color Wheel is Ok? Pull Lamp out Then turn Tv on watch inside to see if color wheel turns it could shattered causing this.
Samsung HLN567W... | Answered on Mar 01, 2011
Most likely a faulty power supply, any TV repair shop will be your easiest bet, or if your any good with electronics you could try and replace it yourself
Samsung HLN567W... | Answered on Jan 11, 2011
Mine does the same thing. It makes a regular popping sound that does not change in level with the volume control. When the popping starts getting erratic the pixelated sound starts and in a short time the sound straightens out for the rest of the viewing time. However, the next time the cycle repeats itself. Did you find a fix?
Samsung HLN567W... | Answered on Jan 01, 2011
If you had a pix before just a niosy color wheel then I would double check and make sure you have the right one for that engine. Next, re check all your connections. I hope you have the lamp door in place?
Samsung HLN567W... | Answered on Dec 10, 2010
Samsung HLN567W 56" Rear Projection HDTV Logo
71 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
sound tv just clicking
  • Televison & Video
