20 Most Recent
Canon Pixma Mx459 All-in-one Inkjet Scanner/copier/printer/fax Questions & Answers
Trying to use adf but tells me to put original on platen
You need to check the settings for scanning. The machine wants to use the platen because that is what it has been set up to do, or you are using a sheet size the machine doesn't know about. Again go through the scanner settings both on the machine and any attached computers.
No matter whatido cant send fax keeps saying off the hook
Try unplugging other phones (from the phone jacks) that are on the same line. Also, remove any phone that is plugged in to the fax machine, if there is one attached. If that doesn't work, swap the phone cable on your all-in-one printer/fax with a different one. Lastly, try a different phone jack all together.
I can tell you I had the same problem with my fax/printer, and it ended up being a bad phone cable. It, the cable, worked fine with a handset, but not with the fax. Good luck.
My fax machine is saying off hook but the printer is working
Hello, my name is Steve. It sounds like your Fax machine has detected that the phone lie to your machine is still "opened".
The Fax board that detects the signal for the incoming fax tone is either not connected or it has an open circuit.
If you have another cable that goes to the Fax try this as a replacement. If this corrects the problem, then the fault is the cable from the connection of the wall to the fax machine.
If this does not, then if you have another source, connect it...like a telephone. If you hear a dial-tone then it is not the line-in.
The part that failed is the Fax-card or the Logic board...
I hope this helps, best regards,steve
I have a problem with my canon printer g3411. It has an error P03 but no paper jam. How do I solve my problem
Error P03 on a Canon printer typically indicates a paper jam, even if you cannot physically see any jammed paper. Here are a few steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Carefully check the paper tray and inside the printer for any jammed paper or debris.
- Remove any jammed paper or debris you find.
- Plug the printer back in and turn it on.
- Attempt to print again.
If you don't see any paper jammed in the printer, there are a few other things you can try to resolve the error P03:
- Try resetting the printer. To do this, turn off the printer, unplug it from the power source, and wait for a few minutes before plugging it back in and turning it on.
- Check the ink cartridges and make sure they are properly seated and have enough ink.
- Clean the printer's rollers. Rollers are the small rubber wheels inside the printer that move the paper through the printer. Over time, dust, debris, or ink can build up on the rollers and cause paper jams. Cleaning the rollers can help resolve the issue.
- Try to update the firmware of the printer. Sometimes, a firmware update can resolve the issue.
- Check the printer's settings, ensure that the size of paper loaded match the size of paper set in the settings.
If the problem persists after trying these steps, you may want to contact Canon support for further assistance.
How to slove error e732-001 of canon ir 3225
The E732-001 error on a Canon iR 3225 indicates an issue with the fixing assembly temperature. Here are some steps to troubleshoot and resolve this error:
Reset the Condition:
Enter service mode by pressing the following sequence on the control panel: COPIER > FUNCTION > CLEAR > ERR.
This will reset the error condition. If the message disappears, your printer is ready to use. If this doesn't work, there may be a hardware problem as addressed below.
Replace the Main Thermistor:
The main thermistor is responsible for temperature sensing. If it's faulty, it can trigger the E732-001 error.
Consider replacing the main thermistor to resolve the issue.
Check the DC Controller PCB:
If the problem persists, inspect the DC controller PCB for any defects or malfunctions.
Replacing the DC controller PCB may be necessary.
Remember to turn off the printer before performing any maintenance tasks. If the error persists or if you need further assistance, I recommend contacting your local authorized Canon dealer or the Canon Customer Support Center for professional service
