20 Most Recent Xerox ColorQube 9201P Questions & Answers
Make Sure the Paper Trays Are Configured With the Correct Paper Size, Type, and Color
To configure settings for Paper Trays 1 and 2
  1. Open the paper tray.
  2. Make sure that the required paper stock is loaded in the paper tray, and that the paper edge guides are adjusted properly to fit the size of the paper.
  3. Close the paper tray. The Printer Settings screen will be displayed on the Touch Screen.
  4. Select [Size], and then select the size of paper loaded in the tray. If this is a standard size paper, the correct size will be selected automatically if the paper guides are adjusted correctly. If necessary, select [Custom] to enter the paper size if the required size is not displayed and then enter the required X and Y values.
  5. Select [Save].
  6. Select [Type], and then select the type of paper loaded in the tray.
  7. Select [Color], and then select the color of paper loaded in the tray.
  8. Select [Confirm].
Xerox ColorQube... | Answered on Apr 15, 2019
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Xerox Office... | Answered on Jun 20, 2019
you need to reload the printer driver. the proper one for that OS and your network. once that is done the prints will actually print the way they are supposed to. if the driver reload doesn't automatically fix the problem you may need to manually go in through devices and printers and find the printer on the network and install it manually that way too.
Xerox Office... | Answered on Jun 15, 2019
How to enter Singer sct-29fkec service mode
Xerox Office... | Answered on Jun 08, 2019
what ever the market will bear? how desperate are you?
Xerox Office... | Answered on Jun 07, 2019
Solutions for : Fault Code 303-777, 303.777.00: Power Lost Detected Related Fault Code: 303-777, 303.777.00 Solutions ranked by relevance:
  1. This Problem Requires Additional Assistance. Contact Support
We provide support to the greater California area.
Please contact your support provider for this issue.
If you do not have one you can contact us at 858 573 6300.
Xerox Office... | Answered on Jun 05, 2019
Kindly provide solution of wavy print in xerox 5755.
Whatsapp 00923334298796
Xerox Office... | Answered on Jun 04, 2019
Xerox ColorQube 9201P Logo
3 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
fix error code 094 534
  • Office Equipment & Supplies
