20 Most Recent Samsung HT-WP38 System Questions & Answers
i've had a similar problem where the fan stopped moving and the system gave the usual "protect" error. i think the IC's burned out on the amp board since the error was no longer there when i unplugged it. i ordered a new board off ebey for $25 shipped. make sure this is the problem by unplugging both the power and data cables from the amp circuit (the board with the big heatsink) and starting it. if it says starts normally then the problem is the amp circuit
Samsung HT-WP38... | Answered on Apr 22, 2019
Does it have a fan in the back? Is it spinning? If it does have a fan that is not spinning, you may be able to replace it. Another possibility is a short in the speaker wiring, check the wires to make sure that a strand or wire is not contacting another wire...
Samsung HT-WP38... | Answered on Jun 16, 2015
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Samsung HT-WP38... | Answered on Aug 22, 2010
I assume "PROT" means some sort of protection mode. I would check to see if any of your speaker wires are crossed at the speakers or the receiver. If not you may have shorted something internal.
Samsung HT-WP38... | Answered on Mar 18, 2010
with the receiver power off, hold down the stop button on the front of the receiver for 5 seconds. it will reset the system.
Samsung HT-WP38... | Answered on Aug 19, 2009
you can purchase a new one at www.samsungparts.com or you can order here 1-800-627-4368
Samsung HT-WP38... | Answered on Jun 30, 2009
See other post:
http://www.fixya.com/support/t947290-dvd_not_loads
hope that helps
--JeD
Samsung HT-WP38... | Answered on Jan 24, 2009
Same problem!
go to menu unlock childlock
Samsung HT-WP38... | Answered on Aug 14, 2008
It is likely that the optical fiber inside the cable is broken, it is really sensible and gets damaged easily. I'd try changing the cable before even opening the home theater.
Samsung HT-WP38... | Answered on Mar 30, 2008
You can open the dvd and try to clean it manualy.open the dvd so you can see the lazer.take a normal earbud and wet it with normal methylated spirits and clean the lazer gently with that.the lazer cleaners hardly ever work 100%.Just remember not to push to hard on the lazer or you will brake it.gently clean and wait for lazer to dry and try again.
Samsung HT-WP38... | Answered on Mar 28, 2008
Check to see if your phone's do not disturb is on. I had a phone that after repeated volume adjustments started turning it on without me realizing it.
Samsung Audio... | Answered on May 17, 2019
Samsung HT-WP38 System Logo
Popular Tags
21 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
same probleme ht x250
  • Audio Players & Recorders
