20 Most Recent Android LG Optimus Dynamic II LG39C Smartphone fo Questions & Answers
Go To Setting - Mobile Network- Access Point Names- Click Option Touch And Create New APN
Android LG... | Answered on Sep 05, 2016
The only way to get back into your device is to do a factory reset. Keep in mind, Google has an activation lock to prevent theft of your device. With that being said, after you factory reset your phone it may ask you to login to the original gmail account that your device was set up with.
To do a factory reset, you need to boot the phone into recovery mode:
  1. Power down the device
  2. Hold down the following keys:
    Volume Up + Home + Power
    or
    Volume Up + Home + Search
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
Android LG... | Answered on Feb 23, 2016
Sounds like the proximity sensor. The phone has a sensor that attempts to determine if the phone is up to your ear, and then shuts the screen when it is to save battery. However, if you have a screen protector of any sort it can block the sensor, making the phone think it is up to your ear once you place the call.
Easiest way to test this is to disable the proximity sensor then place a call. If the screen does not instantly go black after you place the call, then you know for sure something is blocking it. If you have a screen protector, try removing that.
To disable the sensor:
  1. Goto settings
  2. Call settings
  3. Additional settings
  4. Uncheck the proximity sensor box
hold volume down and power button to enter reset mode
Android LG... | Answered on Jan 19, 2016
Find its icon and tap it.
Android LG... | Answered on Dec 01, 2015
you don't but if you quit using it for the internet perhaps it will come up less often.
Android LG... | Answered on Nov 30, 2015
They do die from time to time . put on charger .
Android LG... | Answered on Sep 16, 2015
you already got the problem there. Insufficient funds. that means you doesn't have enough balance to send text message. But if you sure you have enough then contact your network provider and complain to them because it will be their error not the phone
Android LG... | Answered on Jul 31, 2015
Yes you can call 911 with this phone (andriod optimus dynamic 2 LG36C smartphone. You can either go to the unlock screen and click emergency call or you could go to the dialing screen and dial 911. I Hope this was help to you!!
Android LG... | Answered on May 25, 2015
you can not transfer the apps that are installed as they have been installed into the phones memory ? you can download the full app onto the card then install onto the phone. ( when an app is installed into the phone it needs "bits" of the phones software to run so its "sort of " all in small parts scattered all over the phones memory ) a downloaded app is a complete all in one program,it only gets sent all over when installed... only way to save room is to "uninstall" some apps
Android LG... | Answered on May 08, 2015
try a reboot or restore both options are in the following menu. turn off phone. press and hold the volume up button and the home button ( on the front ) now with a spare finger turn the power on ( keep holding the 2 buttons ) you should see the green android then a menu. if you dont see it then turn off and try again. only leave go of the buttons when you see the little green android man
Android LG... | Answered on May 01, 2015
you can use speed dial to call some selected numbers you personally choose to call. it is fast to call the phone number just by long pressing a key from you keyboard.. Moreover, you can use keys from 2-9 one your keypad but 1, is reserved for voice number.
Android LG... | Answered on Apr 06, 2015
Open the photo gallery album and select a photo, tap the "menu" key, then tap "move", and select destination.
Android LG... | Answered on Feb 18, 2015
There are a couple of ways to see your minutes. One would be if you go to your settings then go to your phone or account info. Then it will show you what your minutes are.
Android LG... | Answered on Nov 11, 2014
Some providers and or phones have a time limit on the pics sent via txt or mms. Unfortunately idk if you can recover your past pics. But the next time you recieve a pic this way, try tapping and holding the image to bring up the options menu. Then select save image or download image. This will save the image to your gallery.
Android LG... | Answered on Nov 07, 2014
Some phones only hold pics in msgs for a limited amount of time. Next time you recieve a pic msgs tap and hold to bring up the menu on it. The save image. It will download to your gallery. Problem solved
You will need to visit Google.com or contact your cellular phone service provider.
Android LG... | Answered on Oct 15, 2014
Android LG Optimus Dynamic II LG39C Smartphone fo Logo
Popular Tags
22 questions posted
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Android Cell Phones
  • Android Cell Phones
Most Popular Question
get out emergency call frozen no icons
  • Cell Phones
