20 Most Recent TCL E3010 Series LE40FHDE3010 40" LED TV 1920x1080, 60 Hz, HDTV Questions & Answers
2answers
I have a 40" TCL TV with one black vertical line on the screen.
Your set has some board that performs the function to connect the screen to the video-generation function of the TV. Either your LED/LCD screen is failing or the video function is failing. If the set is under warranty, contact the manufacturer using the information on the warranty statement. Try using a different video input (hdmi/composite/etc) for the TV and see if you get the same line on all inputs. If there is no separate board, the next step would be to try and replace the main video board. With the prices falling on lower resolution TV's, it would probably be cheaper to replace the TV than trying a repair, if it is out of warranty. 40" 1080p TV's can be had for less than $200 at some sales (e.g. Black Friday).
1/3/2020 10:56:26 PM • TCL E3010 Series... • Answered on Jan 03, 2020
Tcl l40f10f
try update your TCL TV firmware by current update version file from USB stick https://electronics-tricks.blogspot.com
1/3/2020 10:58:48 PM • TCL Televison &... • Answered on Jan 03, 2020
0answers
L24v10f tcl
Replace the power supply.
6/24/2014 7:19:30 AM • TCL Televison &... • Answered on Jun 24, 2014
0answers
0answers
0answers
Tcl tv repair
It sounds that the main system control memory IC is faulty. Replace it and check. This is a very cheap to buy IC. Eventhough its cost and size is small, the function of it when the set is switched ON, is great. It is a very small IC, having only 8 solder terminals. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window
10/12/2013 2:38:16 PM • TCL Televison &... • Answered on Oct 12, 2013
Tcl l32m19 tv wont turn on woke up the other day and the light on the front was not on
Power supply regulator section [mains] to your TV should be troubleshooted. This is a skilled work.
6/27/2012 12:24:31 AM • TCL Televison &... • Answered on Jun 27, 2012
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 hours ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 4 hours ago
2answers
My Telefunken television model TLEDD-42FHDB remote made tv on/off switch flick and remote has stopped working now. Still doesn't work after replacing batteries.
Put the batteries back in and aim the front ot the remote at the front facing selfie camera on a smartphone. Press a button and you should see a flash. If no flash, the remote has failed. If there is a flash, the television IR module or main board has failed.
Telefunken Replacement TV Remote TLED-26FHDPA
Soundtech https://soundtech.co.za > telefunken-replacement-tv-rem... Telefunken replacement remote compatible with TV models: TLCD-29FHDP TLCD-32FHDA TLCD-32HDA TLCD-37FDHA TLCD-37FHDA TLCD-39FHDP TLCD-40FHDC TLED-26FHDPA ZAR 199.00 ..
4/15/2024 10:04:39 PM • Televison &... • Answered 22 hours ago
2answers
Venturer KLV39103 10" Kitchen LCD TV/DVD Combo. I need an adapter to change to HDMI for an EVOForce cable box. Where can I buy one.
Question edited for a lot more clarity, full 'make model (what it is)'. There is more to this that meets the eye because your set is analogue and the new cable box is digital. Have a read
Is it possible to modify my kitchen Venturer KLV39103C tv in
JustAnswer https://www.justanswer.com > TV Problems Jun 9, 2021 - Your TV has only one external input and it's an analog coaxial input, hence why the converter and modulator will be needed. 1 answer ยท Top answer: You are very welcome. In my opinion, it would be much simpler to simply j More here https://www.google.com/search?q=venturer+klv39103+convert+to+digital ..
4/14/2024 8:05:32 PM • Televison &... • Answered Yesterday
2answers
TCL E3010 Series LE40FHDE3010 40" LED TV 1920x1080, 60 Hz, HDTV Logo
2 questions posted
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
john h
ADMIN Andrew
ADMIN Andrew
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • TCL Televison & Video
Most Popular Question
40 tcl tv one black vertical line
  • Televison & Video
