20 Most Recent
Air Conditioning and Heat for Nissan Quest Questions & Answers
Heat not working when in park
When idling the water pump is pumping less so you might have low antifreeze or coolant Check that first...if it is ok and the heater gets warmer when the throttle is pushed..your waterl pump is getting weak..need to check that. Could leave you down without warning...good luck
Tappet clearance intake exhaust valve
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj5xrGigOKBAxUdgP0HHQ9gCWIQrAIoAXoECCQQAg&url=https%3A%2F%2Fwww.fixya.com%2Fcars%2Ft29759728-1991nissan_civilian_3_5lt_please_tell&usg=AOvVaw3L1RXEvVBAFwp8YjNQOz34&opi=89978449
My 2000 maxima keyless entry is not working.
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals free
2005 nissan air condition noise clicking inside car
Maybe something hitting the fan blades in the blower? There isn't much inside the car that's specific to the A/C- evaporator, maybe an expansion valve, and some hoses. Most everything else is in the engine compartment. The blower, dampers, and controls may have a problem, but it probably wouldn't be limited to just the A/C
My ac fuses always over heating when the ac is on
If you're saying that you keep blowing the AC fuse when it's running, then you have a problem. The fuse is there to protect the system from an electrical problem. Burning a fuse element means the AC is drawing too much current. Probably a short somewhere.
NEVER replace a fuse with a higher rated fuse- use only the Amperage rating suggested for that circuit.
Why doesn't my driver side window not roll up or down on my 06 nissan murano?
Some new cars have bent windows. If these windows aren't installed properly, from the scraping sound they make, in time they wear out and the lifting mechanism breaks down, resulting in a clanking noise to no noise at all. Can you hear anything whilst you're trying to open and close the window? If so, then it is damaged from being forcefully operated by the overstrained motor. If you hear nothing, then it may be a fuse, and that too could be also be a reason it has fused by the overstrained motor. Best to take it to a dealership and have it fixed.
