20 Most Recent Sony HDR-PJ240E/B Full HD Handycam Camcorder Black, PAL Questions & Answers
Why when I use the inbuilt projector of the Sony Camcorder HDR-PJ240E with an external device,the projected screen becomes plain blue after a few minutes?
This maybe due to the external device not receiving signal to keep the display on the screen or a cable that isn't quite right. Many HD cables can cause this issue due to a security feature built into it to prevent streaming copies which helps prevent piracy. If you are using say an HDMI cable, try a different one.
11/26/2014 8:54:08 AM • Sony... • Answered on Nov 26, 2014
How do I project a picture from an external device through the inbuilt projector of the Sony HDR-PJ240E after I have connected from the HDMI out of a DVD player and into HDMI Projector IN of the Camco
hi, the HDMI connector on your cam is only an output, not an input ! so... you can't sorry... cheers
11/26/2014 12:08:39 AM • Sony... • Answered on Nov 26, 2014
2answers
It is brand new and the store has exchanged it for another Camcorder and it is still the same problem
I Will continue adding my two cents to all of these posts :) Another thing to try I haven't mentioned would be to play a movie that you know is PAL. Since the camera is PAL. Color info and reference freq. is different. In fact unless you remove region codes all together use a converter box there is no way to play a movie that is NTSC. It wouldn't even read out on your LCD screen in the spot where it is suppose to be.
11/25/2014 3:22:31 PM • Sony... • Answered on Nov 25, 2014
How to project external device through the SONY HDR-PJ240
  • -Open LCD screen
  • -Press the 'View images' button to enter playback mode which looks like > with a square around it
  • - Then use < and > on screen to SELECT the DVD
  • -On this same screen TOP Right Hand corner of the screen you see the format mode. Select the SAME format as the file your trying to play.
11/25/2014 8:43:26 AM • Sony... • Answered on Nov 25, 2014
How to project an image from an external device from a Sony Camcorder HDR-PJ240E?
Simple solution. You connected an output to an output. The Camcorder 'outputs' image from it so you need to plug it into an input on your TV. You will then see image from the camcorder on your tv.
11/25/2014 8:14:48 AM • Sony... • Answered on Nov 25, 2014
Sony HDR TG3 Video Camera. The lens cover stuck closed
Question edited for a lot more clarity. Question moved to Sony HDR category. AI Answer Bot bad answer deleted.
Lens Cover Doesn't Open or Close Properly
Sony https://www.sony.com > electronics > support > articles Solution. The lens cover won't open if the camera's date and time isn't set. Set the date and time and perform a power cycle on the camera. ..
9/13/2023 12:11:17 AM • Sony HDR Video... • Answered on Sep 13, 2023
4answers
Best way to convert m2ts video format to mov format?
MTS and M2TS format is a Sony hd camcorders and Panasonic camcorders format.if you want to edit your video clips by imovie than you have to convert it to imovie suitable format.you can convert it mov format bfor edit.mov format is commonly use and most preferred for imovie.just download a good converter. http://www.aimersoft.com/convert-mts/convert-mts-m2ts-to-mov-mac.html
4/22/2020 3:25:23 AM • Sony HDR Video... • Answered on Apr 22, 2020
0answers
Owners manuel
You can download the manual you need here, free of charge: Sony HDR HC9 manual
1/18/2015 10:00:21 AM • Sony HDR Video... • Answered on Jan 18, 2015
Change from record to playback mode
If you need help alternating between the modes as well as adjusting any other settings, the user manual for the device should cover everything you need: Sony HDR HC9 manual
1/17/2015 6:44:59 PM • Sony HDR Video... • Answered on Jan 17, 2015
Yellow tint on display screen
hi you must have a broken wire in the flat ribbon of the LCD (the one for the blue colour). you have to replace it cheers mich
11/25/2014 11:53:55 PM • Sony HDR Video... • Answered on Nov 25, 2014
0answers
0answers
0answers
E:94:01
Be the first to answer 11/25/2013 9:46:00 PM • Sony HDR Video... • Posted on Nov 25, 2013Be the first to answer
Sony HDR-PJ240E/B Full HD Handycam Camcorder Black, PAL Logo
5 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
HDR Sony
  • HDR Sony
Most Popular Question
when use inbuilt projector sony
  • Video Cameras
