20 Most Recent
Air Conditioning and Heat for Mitsubishi Montero Questions & Answers
I have an issue where
If you are 100% sure it is just plain water then the drain line for the A/C condenser is stopped up. Crawl under the car and find it. Use a piece of stiff wire with the end bent over the clean out the drain. If the water tastes sweet then the heater core is leaking and needs replacing.
Not colling well
or heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
Diesel engine fault finding fuse 14 keeps blowing
Isolate the circuit remove all devices from it but one, if that one does not blow the fuse, disconnect it, and reconnect another one in that circuit till you find the culprit.It's not always that easy, but good luck
How do i remove the front brake disk on a 96 pajero
The hub needs to be removed from the car the disc is held on by bolts through the rear of the hub. If you have no experience working on brakes I would recommend that you leave this to a competent workshop. It is quite involved and impacts on yours and others safety. (Read Life!)
How to remove rear rotor on 95 pajero
after you jack it up and remove the tire you then need to remove the caliper and brakes. then the rotor should just slide off sometimes it may need just a slight bump with a hammer on the backside
