20 Most Recent
Breezaire WK2200 (265 cu. ft.) Wine Cooler Questions & Answers
My 2200 unit stoped cooling why
IF YOUR UNIT IS A WK2200 IT SHOULD HAVE A SCREW ADJUSTMENT(THERMOSTAT) IN BETWEEN THE TWO BROWN GRILLS. IF SO IF THE FANS ARE RUNNING ON BOTH SIDES COLD AND HOT SIDE, AND NO COLD AIR IS BEING PRODUCED YOU PROBABLY HAVE A FREON LEAK AND THE UNIT REQUIRES A RECHARGE AFTER REPAIRING THE LEAK.
My thermostat is reading 48 and I can't get it
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
WK3000-7 yrs old. Stays on
Hi!!
Check your temp. settings and that the fan in the freezer/refrigerator is working, if items are working, (normal settings are about 1/2 way of the dial range). then your problem is a Refrigerant leak. When refrigerant level is low, the lines start to freeze but as soon as the compressor stops, the ice will melt. When there is a problem with the.defrost timer or the defrost coil, Ice builds up and takes up to a day with the fridge open to melt.
The repair of a leak in the system should be performed by a qualified HVAC Technician.
I suggest to call and ask how much would it be to repair the leak, then you decide if it is worth fixing or just replace it.
Good Day!!
9/26/2010 8:59:34 PM •
Breezaire...
Answered
on Sep 26, 2010
Have a Breezaire Sentinel II
If you wish for a Local Repair, tell me the Zip Code and i would try to Search for a Serviceman from our Listings.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/19/2010 4:02:32 PM •
Breezaire...
Answered
on Jan 19, 2010
