20 Most Recent
Northland 42SSWGX2 Side by Side Refrigerator Questions & Answers
Northland D36R fridge parts
do online search for parts and pick a site that has exploded views and pick the parts you want and copy down the part number or order the parts
11/6/2021 12:39:25 PM •
Northland...
Answered
on Nov 06, 2021
I have a Northland freezer/fridge
Start by making sure the box is square -- that the doors are perfectly parallel across the top, with respect to the outside of the box. You fix that problem by adjusting the front feet on the fridge to square up the box. If the doors are all square and the fridge door is still low, look for some adjustment in the bottom door bracket - may have some slots where you can loosen mounting screws and adjust upwards. This may take two people or a lever (maybe a piece of lumber) as you have to raise the door while you're making the adjustment. OR remove the top bracket, remove the door and set it aside then try adjusting the bottom bracket and replacing the door and top bracket.
8/12/2018 2:54:53 AM •
Northland...
Answered
on Aug 12, 2018
14" ...freezer on top...
freezer seems
yes ice is probably your problem, defrost the the unit top and bottom over night at least doors open if warm climate try it again if it reoccurs after two to three weeks then its not doing a defrost test element in freezer for continuity
2/10/2018 2:02:50 AM •
Northland...
Answered
on Feb 10, 2018
