This answer on Pinterest:
How to Fix Code E2 on Singer Fashion Mate Sewing Machine 7256 eHow
In case you are unable to view--here is the text:
The Singer 7256 Fashion Mate sewing machine has a top drop-in thread bobbin and an automatic needle threader. The digital display on the side of the machine is used to select different stitch settings on the machine. When the display reads error code E2, it means that there is a bobbing threading error, which may be caused by the thread looping or bunching under the fabric as you sew.
Things You'll Need
Pen
Screwdriver
Push the bobbin-winding spindle of the sewing machine back to the left.
Turn the hand-wheel toward you, hold the needle thread (thread on the sewing machine needle) and tug it lightly as the needle goes down and then raises up. A small loop will raise up through the needle plate on the sewing machine. Use the tip of a pen to lift the loop up through to the back of the machine.
Check the position of the needle. It should be seated in the sewing machine with the flat side facing the back of the machine. If it is not, remove the needle and reinsert it so that it is facing the correct way.
Remove the bobbin case. Use a screwdriver to turn the screw on the side of the bobbin until the loops of thread pull taught and are removed.
Remove any loose fibers or threads that may be stuck in the tension disks.
Reset the upper tension disks. Raise the presser foot lever up. Put the tension setting of the sewing machine on setting "4." Hold onto the spool of thread in your right hand and with your left, route the thread down through the tension channel, around the bottom of the disk and up the other side. When done correctly, the thread will click into place and slip in between the tension disks.
Set the thread bobbin in the bobbin case, with the thread passing over the top of the bobbin and then down to the right. Route the thread through the notch located at the left of the bobbin case and pull it through. Move the thread over the top of the throat plate and over to the back of the machine.
Tips & Warnings
Using incorrect bobbins may cause error E2 to occur. Not all plastic bobbins are the same size, so check the model number of the bobbin to ensure that you are using the correct one with your sewing machine.
Never turn the hand-wheel on the sewing machine away from you, as it will change the timing on the sewing machine.
If your bobbin winder is not working correctly, you can pick up a stand-alone bobbin winder (one brand is called Sidewinder) online or at most franchise fabric stores, ie Hancock's or JoAnn's, for around $25.
No I don't think it will. That attachment is for a 'Slant Shank' machine like a 301.
The K on the Sewing machine model number simply means it was built in Scotland. That means it is basically the same as most other 201's.
Question edited for clarity.
Do you mean the embroidery unit. If it is secondhand and has been stored for a long time, sewing machine oil, or worse WD40 goes 'gummy'. You would need to clean all the out. WD40 is a good solvent, so spray, leave it to soak, spray again and agitate with a brush. The wash it all off with hot soapy water. Dry thoroughly and after a few days, lubricate metal parts with sewing machine oil and any plastic parts with a dry silicone spray like Jigaloo. Test Jigaloo on a flat piece of plastic first as it is also a powerful fast drying solvent.
In the event that your Vocalist Quantum Beautician 9980 isn't playing out the needle change and won't sew, there could be a few issues. To begin with, guarantee the machine is strung accurately, and the bobbin is appropriately embedded. Check in the event that the needle is embedded accurately and not harmed. On the off chance that the issue continues, counsel the client manual for investigating tips or consider reaching Artist client assistance for additional help.
Lois, all questions need full 'make model (what it is) please. Futura is a range of models so ''Singer Futura' isn't specific enough. Add the model number after the word 'Futura' and press enter.. You can also look for the Service Manual. There is one in the link, but no Error 20.
https://www.google.com/search?q=Singer+Futura+Error+20
DON'T cut lumps out of your machine. There will be a sequence you use to remove the parts you need to access to the gears more easily. The Youtuber you referred to sounds like they have zero knowledge when it comes to these older style machines.
'Note' Some of the gear mount nuts are on a "Reverse" thread meaning you turn them the 'wrong' way to get them off.
My limited knowledge is more on the much older hand crank and treadle machines.
Try the Youtube link below for a channel called 'Andy Tube'. He has a good reputation for correct repair methods. The link is for a 758 but they're both Touch and Sew machines.
You could also try the Facebook group 'Vintage Singer Sewing Machines' as they have loads of knowledge about loads of different machines.
https://www.youtube.com/watch?v=zxd5hKjGBlE
