FixYa.com
Ultimate Sound TA2600 Car Audio Amplifier
All Products > Ultimate Sound > Car Amplifiers
Problems with Ultimate Sound TA2600 Car Audio Amplifier?
Search inside Ultimate Sound TA2600 Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Ultimate Sound TA2600 Car Audio Amplifier RSS Feed Post a New Problem
Ultimate TA2600
Ok, my amp stoped working recently and i took it to an audio shop and they told me that the amp was in protection mode. ...
1 Solution
Amp stays on when car is shut off
Today i was gettin out of my car and i heard a humming sound from the subs, and the amp was still on. the key was out...
3 Solutions
Can I fix a fried amp?
I was hooking up a compaciter and didnt realize the compaciter had a charge stored in it. When tring to hook up to my...
1 Solution
need help with cooling fan
I have a Kenwood Excelon KAC-X301T with the powerslide and my amp is getting hot after about 30 minutes driving...It...
1 Solution
one channel not working
hi, i've bought from ebay one Verge VGA285 as is condition. one ofw the channels is working fine , the other not, when...
1 Solution
AMP not workin
was Driving along and Turned my Fan on and then my Amp blew a Fuse When i replaced the fuse smoke started coming out...
2 Solutions
Protect light flashing/ticking
I had my Infinity 1211a mono amp hooked up to my 2.1 fared cap and 2 Infinity 12" subs and the amp worked for about...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms180 W x 2
RMS Power at 2 Ohms215 W x 2
Performance
Bass Boost Frequency45 Hz
THD at Rated RMS Power.03 %
Signal to Noise Ratio100 dB
Frequency Response10 Hz - 30000 Hz
High - Pass Frequency40 Hz - 240 Hz
Low - Pass Frequency40 Hz - 240 Hz
Dimensions
Depth9.75 in.
Height2.25 in.
Width15.75 in.
Other Features
MOSFET ampYes
Ultimate Sound Contact Information
Main support number1-800-567-3275
Support FAX1-866-450-5507
Email supportinfo@ultimate-sound.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
