FixYa.com
Ultimate Sound DT2-800 Car Audio Amplifier
All Products > Ultimate Sound > Car Amplifiers
Problems with Ultimate Sound DT2-800 Car Audio Amplifier?
Search inside Ultimate Sound DT2-800 Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Ultimate Sound DT2-800 Car Audio Amplifier RSS Feed Post a New Problem
I´ve got 2 amps for my subs,but only...
I´ve got 2 amps for my subs,but only one pre-out from HU of course.i know i should be using amp´s line out to...
1 Solution
Need a power connector for a Boss IQ 3KD.1...
Where can I find a replacement power connector for a Boss IQ 3KD.1 3000W Class D Monoblock Amplifier. The screw loosened...
1 Solution
Amp isn't putting out any sound
My amp just up and quit and now it won't put out any sound. It will power on but that is as far as it gets and the LED...
1 Solution
what ohm load is best?
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what...
1 Solution
8 Ohm Load? Why?
I was playing with the woofer wiringwizard, and for (2) 4 Ohm subs it shows how to wire it so the amp sees 8 Ohms. i was...
1 Solution
power light
My amps power light does not work, is there anyway I can make it work again?
1 Solution
12.6 from battery
In recent topics I heard that a regular car battery with no upgrades can have about 12.6 volts. My? is if an amp such as...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms200 W x 2
RMS Power at 2 Ohms400 W x 2
Performance
Bass Boost Frequency45 Hz
THD at Rated RMS Power.1 %
Signal to Noise Ratio90 dB
Frequency Response15 Hz - 25000 Hz
High - Pass Frequency5 Hz - 45 Hz
Low - Pass Frequency5 Hz - 45 Hz
Dimensions
Depth14 in.
Height2 in.
Width10.6 in.
Other Features
MOSFET ampYes
3 Way ReadyNo
Ultimate Sound Contact Information
Main support number1-800-567-3275
Support FAX1-866-450-5507
Email supportinfo@ultimate-sound.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
